Members Teradee Posted November 18, 2022 Members Report Posted November 18, 2022 Hi everyone! I bought an old singer 18-3. I cleaned it up, oiled it up, and it sewed for a few rows and now I can’t figure it out to save my life. it is not catching the bobbin thread now, but when it was, it was not sinching the stich down and the bobbin side was laying flat on the leather with small loops holding it there (I assume the tension?). Im in Wisconsin. Anyone know a way to get that machine to be a solid, less finicky machine? thanks! jason Quote
Members Burkhardt Posted November 18, 2022 Members Report Posted November 18, 2022 Should we guess at where in Wi? Quote
Members Constabulary Posted November 18, 2022 Members Report Posted November 18, 2022 (edited) Sounds like a timing issue. I would check the needle hook timing and (most likely) lower the needle bar if necessary. Also make sure the needle scarf is facing toward the hook and needle (as well as the whole machine) is threaded correctly. When the bottom thread is flat you either have a tension issue or a too small needle size or a too thick thread. This chart will help to find the right needle size / thread size combination: https://www.tolindsewmach.com/thread-chart.html Here s a Singer 18 manual. On page 13 (last page) you find instructions for adjusting the needle bar: Singer 18 Manual.pdf This Seiko TF-6 manual should give you some instructions that will work for the Singer 18-3 as well: Seiko TE TF-6, -6B Instruction Manual.pdf Edited November 18, 2022 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Teradee Posted November 18, 2022 Author Members Report Posted November 18, 2022 16 hours ago, Burkhardt said: Should we guess at where in Wi? Ozaukee Cty. 14 hours ago, Constabulary said: Sounds like a timing issue. I would check the needle hook timing and (most likely) lower the needle bar if necessary. Also make sure the needle scarf is facing toward the hook and needle (as well as the whole machine) is threaded correctly. When the bottom thread is flat you either have a tension issue or a too small needle size or a too thick thread. This chart will help to find the right needle size / thread size combination: https://www.tolindsewmach.com/thread-chart.html Here s a Singer 18 manual. On page 13 (last page) you find instructions for adjusting the needle bar: Singer 18 Manual.pdf 416.06 kB · 7 downloads This Seiko TF-6 manual should give you some instructions that will work for the Singer 18-3 as well: Seiko TE TF-6, -6B Instruction Manual.pdf 780.26 kB · 0 downloads Great info!! Thanks! Quote
