12 minutes ago, paloma said:
It's really easy to transform a straight beveler into a rounded beveler, I did it the other day and it took me 10 minutes.
Nice tip on using twine coated with rouge.  Will give that a try for stropping inside the curve.
  • Replies 24
  • Created
  • Last Reply
Top Posters In This Topic
So you did this with just a twine and rouge or file it first and clean it up with cord/rouge? My last ordered said it “rounded edges” but it too was square. I’m about to give up and go crazy…….
Thanks,
Dano
  • CFM
Thanks,
Dano
The square ones will still give you a round edge after you burnish it.
Thanks,
Dano
hey hey, no no I didn't do it with just the string and green clay, I did most of the work with the file and only then finished with sandpaper and string.
On 12/4/2022 at 12:14 AM, Danotriglide said:
Also….which side did you work? Left or right in my picture?
Thanks,
Dano
in the back of the tool: L
time does not respect what is done without it
https://tradisign.blogspot.com
https://www.instagram.com/tradisign/
Yes, but depending on the use it can take years.
Thank you Paloma for the pics, I figured this is how you did it. I’ve tried but for some reason I can’t get the angle just right and can’t get it sharp enough to cut clean. I’ll keep picking at it I guess.
Thanks again!
Dano
yes you have to persevere and with a good round soft file it should happen.
