Greetings everyone, I am try to get the dimensions of the screw that locks the stitch size for a Singer 45K92. Attached is a picture of the screw and nut in question. Any help will be appreciated. Thanks much
  • Replies 25
  • Created
  • Last Reply
Top Posters In This Topic
That screw is a stop screw and the nut locks the screw. The screw has a ball tip. I´ll post measures later...
Is this one for sale by chance?
Unfortunately no - it is from the machine in your picture ;)
The screw is 34mm long from underside of the knurled head to the rounded tip. The threaded part is 25mm-26mm long.
EDIT:
Outer diameter is 8.5mm
Edited by Constabulary
Correct me if I'm wrong, but didn't Singer generally use proprietary screw sizes and thread pitches?
- Bill
Quote
I actually hate Singer for this.   I had a lathe that used oddball threads like this. It was a nightmare.  I think it was like "mechanical copy protection" back in the day to try to prevent copying.
I wish my machines had simple metric threads. Even standard SAE threading would be fine.  I loath flat tip screws too.  Was wondering of anyone sold Singer threaded screws and bolts with torx heads.
It should be possible to use a thread pitch gauge to determine the thread pitch.  Then someone with a lathe could reproduce that bolt.
Yes, this type of thing can drive you nuts just like the screws which go into the top of the cylinder arm of the Juki's LS-1341 and clones like Techsew 2750 or Kobe Ls-1341. It is a "Juki" thread and right now were costing as high as $4.50 CAD ($3.30 USD) each. It took me forever to track down a Chinese copy at what I would consider a reasonable cost.
The cost of odd ball dies would probably be prohibitive for small runs.
kgg
Get me a screw part number and i can get the specs and pitch of the screw.
glenn
Can find that screw in the manual at all. Would appreciate the info
Quote
With a lathe you don't need to use a tap or die.  You set the machine to cut the proper thread spacing by either changing the gears or setting the gear box to a specific speed or both.  It's one of the more difficult things to do on a lathe.
OP if you measure the diameter of the screw,  I can try to look up the size based on a chart someone posted here. It's got singer thread sizes by diameter.  A thread gauge is pretty cheap too.  You could measure the pitch directly.
https://www.amazon.com/ChgImposs-Imperial-Whitworth-Industrial-Measurement/dp/B07J9V9JTK
Edited by Quade
