I have a Singer 111W154 that only get's used once in a while but I have owned it for a long time. Can I switch needle bars, or do something else to get this machine to use the 135x17 needle like the rest of my machines? I learned on it, and I enjoy the sound it makes when it's chewing thru a project.
Thank you
24 minutes ago, 327fed said:
Should use those just as it stands. I as thinking that was the standard needle system for 111.
Some of the 111 models used 126x11
I don´t know if there is anything special on a 111w154 but if 126x11 has the same shank diameter as 135x17 you only have to adjust the needle bar height and you do not need a new needle bar.
EDIT:
This guy here has a 111w154 as well and says at sec 0:26 he is using 135x17 so it should not be a problem.
https://www.youtube.com/watch?v=3dS_tfBNN_s
Edited by Constabulary
Thank you
Yes,we have the needlebars in stock that will allow you to use the larger shank 135x17 needles.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Thanks Bob, so does the needlebar you have to use the 135x17 needle make up for the 8mm difference in needle length?
Thank You
Just for the records - what shank diameter has 126x11? I have not found any data on 126x11.
I threw my last 126x11 away so I cant measure it, but I would like to know as well. I will see if I can come up with it.
It's .007 or .187mm smaller than a 135x17
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Thank You
Same length & even if it was easy to adjust by adjusting height of the needlebar when you install it.The main reason to change is you will have no problems getting needles in any size & points you want real easy.
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Ok, learning moment for me. Are you saying I can adjust the 8mm dfference in needles by adjusting the needle bar 8mm? In my mind it would seem the 8mm would cause my needle timing to be late.
Thank You
Thank You
I think your over thinking it.The length of the needle doesn't matter as long as it's not too long & will hit on the upstroke OR too short & hit the feet over a thick seam.I have changed alot of 111W154's over the years to the common 135x17,you instali the new needlebar,set the height so the hook comes in 1/8" above to eye & sew with it!
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
