Members ZigZag Posted January 26, 2023 Members Report Posted January 26, 2023 Hi all, I want to add a raw edge, single fold, bias binder attachment to my Juki1508. There appears to only be a single threaded hole in the sliding bobbin cover plate and 2 threaded holes closer to the front edge of the bed. Is there a particular style or make of binder I should be looking out for. I’m based in the UK Thanks Nick Quote Typical TSC441, Juki 1508, Singer 201, Singer 29k, Sailrite LSZ, Pfaff 238, Pfaff 335, Adler 98, Adler 166
Members shoepatcher Posted January 26, 2023 Members Report Posted January 26, 2023 (edited) You want to order a binding plate that will fit the 1508. That will allow you to tap and screw the raw edge binder down to it. It has a raised platform to drill and tap screws into. Make sure your screw are flush with the underside of the slide plate. If they hang down, grind them off to flush with bottom. Tennessee Attachment makes on with part # 455-1508-1. However, you are in the UK. College Sewing may be able to get you a raised plate. You may need a new feed dog, throat plate, feet for binding as well. glenn Edited January 26, 2023 by shoepatcher Quote
CowboyBob Posted January 26, 2023 Report Posted January 26, 2023 (edited) We sell alot of these arms part#226292 to people to mount the binders with.It fastens in the tapped hole in the middle of the bed with 1-screw.We also put a tack weld on the backside to keep it from pivoting since this bracket only has 1 screw to hold the binder. Edited January 26, 2023 by CowboyBob Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members ZigZag Posted January 26, 2023 Author Members Report Posted January 26, 2023 On 1/26/2023 at 5:48 PM, CowboyBob said: We sell alot of these arms part#226292 to people to mount the binders with.It fastens in the tapped hole in the middle of the bed with 1-screw.We also put a tck weld on the backside to keep it from pivoting since this bracket only has 1 screw to hold the binder. Expand Thanks cowboy Bob, they have these at college sewing so will try this and see how I get on. Thanks for the advice, much appreciated. On 1/26/2023 at 4:22 PM, shoepatcher said: You want to order a binding plate that will fit the 1508. That will allow you to tap and screw the raw edge binder down to it. It has a raised platform to drill and tap screws into. Make sure your screw are flush with the underside of the slide plate. If they hang down, grind them off to flush with bottom. Tennessee Attachment makes on with part # 455-1508-1. However, you are in the UK. College Sewing may be able to get you a raised plate. You may need a new feed dog, throat plate, feet for binding as well. glenn Expand Thanks Glenn, I’m going to try cowboy bob’s recommendation and see how that works out. But I appreciate your ideas. Quote Typical TSC441, Juki 1508, Singer 201, Singer 29k, Sailrite LSZ, Pfaff 238, Pfaff 335, Adler 98, Adler 166
Members Beanwood Posted January 27, 2023 Members Report Posted January 27, 2023 (edited) I need to do something similar from time to time - but also need to move the folder out of the way - so use a magnetic guide - effectively it's a couple of strong magnets on a bar. Sailrite sells one - but like you I'm in the UK, so made my own. I've just checked and someone on E bay sells them in UK if that helps (Go for the 6" long to give a better guide) FORGET THIS - I've just re-read the OP, and you want to attach a folder, not an edge guide.... (Sorry ) Edited January 27, 2023 by Beanwood I answered the wrong question.... Quote
