48 minutes ago, sportycliff said:
Found a repair shop only a couple of hours away, going in next Monday.
Try size #92,138 might be too large for this machine.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
  • Replies 38
  • Created
  • Last Reply
Top Posters In This Topic
Same problem with #92...
How about 69?
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
8 minutes ago, CowboyBob said:
How about 69?
You might want to check the small finger that keeps the inside of the bobbincase from turning,if it is set too close to the hook it can pinch the thread & prevent it from passing through.Run the machine by hand & watch it as the thread passes through this part.
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
checked it and it'll run 207 easily and cleanly.
Ok ,Is there any play in the gears that drive the hook? And have you tried timing it @ 2.2 rise?
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
I'll check for play tomorrow. I timed it with 2.5 (factory spec)?
Packed up and heading to the tech early tomorrow, bit of a ride, but hopefully it'll get straightened out...
