Hello all! With hours and hours of struggling to figure out the tension issues on my 111w155, and frankly learning the machine, I I realized I am missing the tension release pin entirely.
I have looked all over to find one and cannot seem to find it. I believe it to be Singer part # 23556?
Basically looking for the pin that release tension discs when feed dog is raised. Thanks all!
  • Replies 23
  • Created
  • Last Reply
Top Posters In This Topic
I usually use a small nail for that
which I cut to size
https://www.vintagesingerparts.com/products/new-replacement-tension-assembly-singer-part-240446
Look at the second picture in this listing. I wonder if the release rod is part of the tension assembly ...
One of the experts here will have the answer.
Edited by AlZilla
quantum entanglement
- Voltaire
- Aristotle
which I cut to size
Unfortunately I’m a total beginner so I don’t even know what it looks like!
Unfortunately not included with this!
Maybe the 223704, tension release plunger
https://www.ebay.com/itm/304404498645
- Voltaire
- Aristotle
That doesn’t look like it. I’m lead to believe it looks like this part (#20).  This is from a previous leather worker thread but no part number or source was disclosed.
Part of the 240446, Tension Bracket
- Voltaire
- Aristotle
I can't attach a pdf. Search online for 111w155.pdf - it's a parts list for your machine.  Maybe you can noodle it out.
You originally said "Basically looking for the pin that release tension discs when feed dog is raised" - I'm pretty certain that 223704. Maybe you're looking for something else.
But here's a question - does the tension release when you lift the presser foot?
I've found, even as a total rookie, that disassembling the whole tension unit, cleaning it and polishing everything that comes in contact with the thread has been helpful. It's straightened me out a few times.
Edited by AlZilla
- Voltaire
- Aristotle
Not sure if it helps, but it goes in here. (See photo). Correct part number listed above in my original post Im(I think).
Anything that fits in the hole will work - nail, coat hanger, prong off corn cob holder, thick paper clip, small drill bit, wire cut out of a fence, etc.
edit: straight shank of a big fish hook, straight portion of a mouse trap spring, section out of a kitchen wire wisk
Edited by DonInReno
