Members LordHoot Posted March 5, 2023 Members Report Posted March 5, 2023 Hey guys, I've been using this site for a while for information on industrial sewing machines, especially how to set up an Adler 69 for binding, which was really helpful. Decided to join and ask for help regarding a problem with a Pfaff 1245. Problem: Randomly, the upper thread forms a loop when sewing nylon webbing (2+ layers). Issue is more visible with 6mm stitch length, but occurs at any length, I usually sew at 3 to 4 mm. Bobbin thread looks fine. See linked videos for details on the issue. I managed to get a high speed capture of the problem occurring, and it seems that after making the stitch, the needle comes out, then the threads coming out of the hole in the fabric sticks with the existing upper thread from the previous stitch and pulls it out, then it never gets set back down properly. When it’s less dramatic, the stitch feels weak. I’ve tried many combinations of lower thread/upper thread tension, more tension makes the issue less frequent, but at some point the bobbin thread pops up and the issue still occurs. For comparison, the same needle, fabric and thread combination on an Adler 69 has no problem sewing this fabric in the same fashion. The thread never pulls up the previous stitch and they are very strong. - I re-timed the machine according to the manual, then checked it over multiple times, adjusted feet motion, needle position, hook timing, take up string and so on. Manual says 2mm after BDC, tried 1.8 and 3mm, but no change. - I’ve tried modifying the tension on the take up spring, changed the tension disc, and bought new thread, but the problem still occurs. - Tried a much larger needle with no success. I’ve seen a similar issue discussed here: https://leatherworker.net/forum/topic/67986-random-loose-top-thread-consew-289rb-1/ But with no solution, it’s unclear what fixed the problem. I did try lubricating the thread by spraying it with silicone lube, but it had no impact on the problem. I’ve reached a point where I’m considering selling it and getting another machine because it doesn’t produce quality stitches. It's a bummer because I bought it used and it seemed in good condition. Do you guys have any idea what could cause this problem? Quote
DonInReno Posted March 6, 2023 Report Posted March 6, 2023 To me it looks like a lack of tension - those stitches are pretty loose. If adding upper tension pulls the knot to the surface, the bobbin may need slightly more tension. I’ve had a worn bobbin case that seemed to have an ok starting tension (drop test), but it had a groove worn in the tension spring and at the angle the thread was actually pulled from the bobbin case it had very little tension. I’m also wondering about the tension release - make sure you aren’t resting a knee on the knee lifter or that can inadvertently reduce tension. Thats a nice looking machine - hopefully you can get it figured out. Quote
Members shoepatcher Posted March 6, 2023 Members Report Posted March 6, 2023 (edited) The stop on the take up spring looks to high. Set it at about 9 o'clock. Then re do the tensions on the top and bobbin case. See if that helps. I would not resell it. Great looking machine. glenn Edited March 6, 2023 by shoepatcher Quote
Members LordHoot Posted March 6, 2023 Author Members Report Posted March 6, 2023 15 hours ago, DonInReno said: To me it looks like a lack of tension - those stitches are pretty loose. If adding upper tension pulls the knot to the surface, the bobbin may need slightly more tension. I’ve had a worn bobbin case that seemed to have an ok starting tension (drop test), but it had a groove worn in the tension spring and at the angle the thread was actually pulled from the bobbin case it had very little tension. I’m also wondering about the tension release - make sure you aren’t resting a knee on the knee lifter or that can inadvertently reduce tension. Thats a nice looking machine - hopefully you can get it figured out. Good idea, I checked the bobbin case and currently there are some wear marks both on the case and the spring, but no grooves. Machine came with a spare, unbranded bobbin case with spring, no marks on it, replaced the Pfaff one with it, tightened the adjustment bolt to the max, it was harder to pull then before for sure. Then swapped the top thread tension spring since it was not strong enough to pull the lower thread through. Once I got a decent setting I still managed to the get the issue a few times, and there is still a lack of tension. No knee lifter interference either unfortunately. 4 hours ago, shoepatcher said: The stop on the take up spring looks to high. Set it at about 9 o'clock. Then re do the tensions on the top and bobbin case. See if that helps. I would not resell it. Great looking machine. glenn Unfortunately that did not help either. I tried a few positions, even something like 7 o'clock and the problem persisted after adjusting tension. Also tried a range of tension on the take up spring, from very weak to very strong and it did not improve the stitch strength and looping problem. For fun I used a screwdriver to pull stitch after stitch to tighten them, and over 20 stitches I had maybe 1" of leftover thread, so it seems there's really a tension problem somewhere. Here's a picture after adjusting the take up string stop down and increased tension. Quote
Members Burkhardt Posted March 7, 2023 Members Report Posted March 7, 2023 Does the tension change on shorter stitch lengths? Quote
Members LordHoot Posted March 8, 2023 Author Members Report Posted March 8, 2023 21 hours ago, Burkhardt said: Does the tension change on shorter stitch lengths? Doesn't seem like it, started at 6mm, then reduced the stitch length a few times while checking tension and it remained the same. Random loops and weak stitches occurred in all settings. Quote
Moderator Wizcrafts Posted March 8, 2023 Moderator Report Posted March 8, 2023 15 hours ago, LordHoot said: Doesn't seem like it, started at 6mm, then reduced the stitch length a few times while checking tension and it remained the same. Random loops and weak stitches occurred in all settings. If the loose thread and loops are always on the top, assume something is randomly grabbing or hard-twisting the top thread, or the bobbin thread is jumping out of position under its tension spring. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
kgg Posted March 8, 2023 Report Posted March 8, 2023 (edited) On 3/6/2023 at 7:47 PM, LordHoot said: replaced the Pfaff one with it, tightened the adjustment bolt to the max, it was harder to pull then before for sure. Then swapped the top thread tension spring since it was not strong enough to pull the lower thread through. I find this statement interesting " tightened the adjustment bolt to the max ". If you are talking about the little tension adjustment screw on the bobbin case that puts tension on the bobbin thread this is probably a good starting point of the loose stitches. If the screw is over tighten the thread tension spring will actually be bent away from the bobbin thread and not put proper tension on the thread which can lead to some funky stitches. You only adjust that screw in or out by about 1/8 of a turn and do a drop test after every adjustment of the tension spring. kgg Edited March 8, 2023 by kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
kgg Posted March 8, 2023 Report Posted March 8, 2023 I forgot to ask what size needle, bobbin thread and top thread combination are you using? kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members LordHoot Posted March 8, 2023 Author Members Report Posted March 8, 2023 1 hour ago, kgg said: I forgot to ask what size needle, bobbin thread and top thread combination are you using? kgg My bad I forgot to write the current setup I use in the first post. Setup: Bonded nylon thread, #69 (A&E) both top and bottom, usually all black but using green to help see the problem, 135x17 DP17 110/18 round point needle. Sewing mainly 1000D, 400D nylon and various width of nylon webbing. 1 hour ago, kgg said: I find this statement interesting " tightened the adjustment bolt to the max ". If you are talking about the little tension adjustment screw on the bobbin case that puts tension on the bobbin thread this is probably a good starting point of the loose stitches. If the screw is over tighten the thread tension spring will actually be bent away from the bobbin thread and not put proper tension on the thread which can lead to some funky stitches. You only adjust that screw in or out by about 1/8 of a turn and do a drop test after every adjustment of the tension spring. kgg Yes this is the screw I'm talking about. Usually it's not set like that, I set the bobbin tension so I can feel a little resistance when pulling it, just enough to keep it tense but nothing crazy. If I tighten it further, I do get increased tension until it bottoms out and the bobbin tension is way too high. Tension feels tight when pulling the bobbin thread before sewing, but even at max tension and proper balance between bobbin and top thread, stitches are still weak. 2 hours ago, Wizcrafts said: If the loose thread and loops are always on the top, assume something is randomly grabbing or hard-twisting the top thread, or the bobbin thread is jumping out of position under its tension spring. Once I get a chance I'll disassemble it and verify if there's any grooves or catches along the thread path. Looking closely at this video which shows how the lockstitch is made on the same model (older but still close enough) I see the same behavior, upper thread drags the previous stitch thread, but then lower thread tension seems to pull it hard enough to form the stitch properly. I'll also keep investigating the lower thread tension while sewing to see if that could explain the problem. Quote
Members dikman Posted March 8, 2023 Members Report Posted March 8, 2023 Have you tried going up one needle size? Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Burkhardt Posted March 9, 2023 Members Report Posted March 9, 2023 8 hours ago, LordHoot said: but even at max tension and proper balance between bobbin and top thread, stitches are still weak Those 2 things can't happen at the same time. Quote
kgg Posted March 9, 2023 Report Posted March 9, 2023 16 hours ago, LordHoot said: Sewing mainly 1000D, 400D nylon and various width of nylon webbing. Looking at you photo's again of where you are sewing the nylon webbing I wonder does this problem still happen? Have you tried sewing two or three layers of the webbing to give extra the thickness? Sometimes you need the extra thickness to allow for the bobbin and top thread to form and tension properly. I know if I tried sewing that webbing with my Juki 1541S, which is probably very similar capabilities wise to your PFAFF 1245, I would run into the same / similar problems. However if I used my Juki 1181N, walking foot machine, it would sew fine. My Juki 1541S hates thin stuff. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members LordHoot Posted March 9, 2023 Author Members Report Posted March 9, 2023 (edited) 8 hours ago, kgg said: Looking at you photo's again of where you are sewing the nylon webbing I wonder does this problem still happen? Have you tried sewing two or three layers of the webbing to give extra the thickness? Sometimes you need the extra thickness to allow for the bobbin and top thread to form and tension properly. I know if I tried sewing that webbing with my Juki 1541S, which is probably very similar capabilities wise to your PFAFF 1245, I would run into the same / similar problems. However if I used my Juki 1181N, walking foot machine, it would sew fine. My Juki 1541S hates thin stuff. kgg All previous tests were done with 2 layers of webbing, which is roughly 2-2.4 mm thick. I did a test run with 4 layers which is around 4 to 5 mm and it definitely made better stitches, had to adjust tension to have the knot in the middle and then loops disappeared, stitches were tight. I tried 8 layers but it was too much for the machine, it seemed like the needle deflected and hook didn't always catch the thread. What I usually sew with this machine is 2-4 layers of webbing, sometimes with other fabrics. I need it to sew 2 layers perfectly as it's used for pocket flaps and loops would be very visible. Could it be like you described, the machine is not suitable for this kind of work? Is there a way to adjust the timing so that it would handle lighter fabrics? Edit: How does this machine compare to an Adler 267 in terms of sewing light/medium fabric? Do you guys have recommendations on sewing machines for that type of work? Edited March 9, 2023 by LordHoot Quote
kgg Posted March 10, 2023 Report Posted March 10, 2023 16 hours ago, LordHoot said: I tried 8 layers but it was too much for the machine, it seemed like the needle deflected and hook didn't always catch the thread. On 3/8/2023 at 8:45 PM, LordHoot said: Setup: Bonded nylon thread, #69 (A&E) both top and bottom, usually all black but using green to help see the problem, 135x17 DP17 110/18 To help prevent needle deflections I would suggest either i) move up to a 135x17 size 20 or 21 needle when sewing thicker materials or ii) change the thread size to V92 and use a 135x17 size 22. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members LordHoot Posted March 13, 2023 Author Members Report Posted March 13, 2023 Quick follow up: thanks for the help, I managed to find a hook timing setting that made a little stronger stitches ( 1.6 mm instead of 2mm on the needle bar after BDC ) works well for 2 layers of webbing, but tension setting is very finicky. Reduced take up spring tension a bit, but corners remain hard to adjust. I also tried a size 20 needle and it works with 8 layers. I had to adjust the knee lifter motion range to lift the needle foot high enough to turn. I'll finish what I started and probably look into purchasing a lighter machine. Do you guys have any recommendation on light/medium duty machines for nylon webbing/fabric? Quote
