jrk65 Report post Posted March 10, 2023 Not sure how "I" messed up this machine. Yes it was operator error. If you sew a straight line at same speed it sews wonderful, speed up or slow down and the stitch length begins to shorten, may or may not come back to normal. If you stop at a corner and let needle go to bottom and start up 1/4 inch then lift presser foot and turn project the next stitch will be very long followed by 2 or 3 normal then it will start to shorten again. Current needle is 25/200 with bonded nylon 277 thread. Have tried dozens of thread needle combos, learned a lot, didn't fix problem. I have watched numerous videos of threading 441 type machines. There are several different opinions about this topic. I have tried them all. Some seem to give more thread tension than is necessary. None fix my problem. Also have spent hours with thread tension. It is not the problem. I also found some old style, steel Juki type bobbins. Not the problem. I have tried a bunch of pressure settings for the presser foot. Some with heavy marks in project, not the problem. Currently have the smooth plate and needle guide that Ferdco uses. That is not the problem. Gets worse with very thick (max thickness) or in a couple layers of soft chap leather 4/5 oz each I have checked belt tension, not slipping. Machine is well oiled and bobbin shuttle etc. are clean and lubed. I have spent hours with the UWE Grosse videos on timing. As stated, if you start of in a straight line it sews like a dream. Very nice top and bottom thread. This project is 10/12 oz veg tan and 5 oz chap; 277 bonded nylon, 25/200 needle Quote Share this post Link to post Share on other sites
kgg Report post Posted March 10, 2023 29 minutes ago, jrk65 said: This project is 10/12 oz veg tan and 5 oz chap; 277 bonded nylon, 25/200 needle Any chance of a couple of photo's of your thread path to the needle? Have you tried moving up to a #26 needle with the V277? Have you tried installing the bobbin so the thread comes off clockwise rather then CCW? kgg Quote Share this post Link to post Share on other sites
jrk65 Report post Posted March 10, 2023 28 minutes ago, kgg said: Any chance of a couple of photo's of your thread path to the needle? Have you tried moving up to a #26 needle with the V277? Have you tried installing the bobbin so the thread comes off clockwise rather then CCW? kgg thanks for asking: as I posted, I have used dozens of poly and nylon, 207 and 277 threads, and needle combos, Ive tried all the different combos of half wrap to full wrap to one and a half wraps around the tension disks. I have not, put the bobbin in reverse or clockwise. Quote Share this post Link to post Share on other sites
Patrick1 Report post Posted March 11, 2023 Enlighten me @kgg on why you would change the rotation of the bobbin except for adding another problem as in screwing up the spring. Quote Share this post Link to post Share on other sites
kgg Report post Posted March 11, 2023 1 hour ago, Patrick1 said: Enlighten me @kgg on why you would change the rotation of the bobbin except for adding another problem as in screwing up the spring. Sometimes parts become weak with use and having the thread spool off the bobbin in the reverse direction can overcome the shortfall. kgg Quote Share this post Link to post Share on other sites
Wizcrafts Report post Posted March 11, 2023 Remove the throat plate and check if the feed dog screws have come loose. Quote Share this post Link to post Share on other sites
Patrick1 Report post Posted March 11, 2023 @Kgg, I'm still not enlightened. What parts become weak? Are you talking about the tension spring? If so replace it. Running the bobbin in the clockwise direction will eventually damage the bobbin spring. Sounds like some kind of folklore with no mechanics to it. Quote Share this post Link to post Share on other sites
kgg Report post Posted March 11, 2023 4 minutes ago, Patrick1 said: What parts become weak? The spring, poor bobbin tolerances, etc. This is used to help determine if the problem lies within the bobbin hook shuttle. If by reversing the position of the bobbin stitches become better you know where the problem lies. kgg Quote Share this post Link to post Share on other sites
jrk65 Report post Posted March 11, 2023 Thanks for the questions/suggestions. This is a fairly new Shuttle/bobbin case. Stitches are perfect top and bottom when it sews. More than likely not a tension problem, which running the bobbin backwards would be likely to address. There is no feed dog, as I mentioned in my post I'm running the Ferdco system of a smooth plate and needle guide but no feed dog. This is not the problem, I know of dozens of these around and they sew nicely. At some point recently, this machine did too! After further investigation I am leaning towards Needle/Walking Foot Timing Thanks for your interest in my troubles Quote Share this post Link to post Share on other sites
RockyAussie Report post Posted March 12, 2023 (edited) 13 hours ago, jrk65 said: There is no feed dog, as I mentioned in my post I'm running the Ferdco system of a smooth plate and needle guide but no feed dog. Does this machine not have a needle guide down under the needle plate? I believe that on most other 441 class machines that this part is where a feed dog is normally in place and what @Wizcrafts is suggesting is that you check that this part has not come loose. As for the needle/walking foot timing I have to wonder why it would be right most of the time and not other times. I would first check that the back walking foot lifts smoothly and easily without any catching This pic shows a screw that allows the roller to be tighter or looser to the guide for the back walking foot - and then also that there is no excessive slop in any of the linkages that connect to the front walking foot and needle bar assembly. Make sure that the connecting rod coming off of the cam on the end of upper shaft has not come too loose or worn out. Many many operators do not do a good enough job of lubricating those knuckles on these rods. They do have oil holes in them and most people do NOT oil them. No video or even most manuals show all of the holes that should be oiled on these machines. Simple ...if it turns/revolves it should be oiled. Edited March 12, 2023 by RockyAussie Quote Share this post Link to post Share on other sites
jrk65 Report post Posted March 12, 2023 Sorry for the poor description in my post. This machine has the Ferdco smooth plate with the needle guide in place of a feed dog. It is not loose. There is no slop in the linkages, or excessive wear in the needle bar. This machine has very few hours of use. Don't wear your church clothes around my machine as there is more than plenty of oil on the mentioned knuckles. Old timers used to tell me grease is cheap. Now I'm and old timer, so is lube oil. I have adjusted the needle and walking foot timing, adjusted the presser foot, and that seems to have fixed the problem. I'm going to stick my neck out here: Timing, Timing, Timing! Thread size, thread brand, nylon/poly/bonded, needle size, to some extent tension, variation in thread path from spool to take up spring. While important, adjusting, changing these things are little more than tiny bandaids, if the machine is not totally in time! Mine was not. Operator error. DIY mechanic error. I have learned many things about these minor adjustments, that will help fine tune my stitching in the future. It seems that these adjustments are what takes a machine that "sews" and makes it in to a machine that "sews really well". That is my goal. Just my opinion. Thanks for your comments/suggestions, they all open up avenues for working through a problem. Quote Share this post Link to post Share on other sites
Patrick1 Report post Posted March 14, 2023 @jrk65 should invest in a XTREME #25 NARROW FEED DOG WITH FLAT STAINLESS PLATE at heprecision.com for your Ferdco. Had a customer purchase one for his Ferdco last week with the same set-up as yours and similar issues. Don't have to stick my neck out here, feed dog, feed dog, feed dog! As @RockyAussie was saying about the oil, it's extremely important. Had another customer who purchased a brand spanking new CB 4500 with feeding issues. Had him pull the side plate, put some oil the presser and center foot bars and everything in between and now it runs as it should. Quote Share this post Link to post Share on other sites
kgg Report post Posted March 14, 2023 1 hour ago, Patrick1 said: Had another customer who purchased a brand spanking new CB 4500 with feeding issues. Had him pull the side plate, put some oil the presser and center foot bars and everything in between and now it runs as it should. Another place people forget too oil is the other end of the bottom shaft that is accessed by opening the two round cover plates on the main part of the machine. Like RockyAussie said: On 3/12/2023 at 10:32 AM, RockyAussie said: Simple ...if it turns/revolves it should be oiled. kgg Quote Share this post Link to post Share on other sites
