kgg Posted April 3, 2023 Report Posted April 3, 2023 1 hour ago, MainiacMatt said: I suspect the problem is being caused below the deck. Since the problem occurs when you reverse I would check and see if the forward and reverse stitch match. Without thread in the needle: Place a piece of heavy paper under the presser foot and sew a seam for say 6 inches then reverse. The reverse holes should match, going through the holes that you created in forward. There should be no variation of spi from the first part of the seam and the last part. This will also allow you to accurately measure spi the machine is actually sewing versus what your stitch length dial setting is saying. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members MainiacMatt Posted April 3, 2023 Author Members Report Posted April 3, 2023 kgg.... thanks for that Quote
Moderator Wizcrafts Posted April 4, 2023 Moderator Report Posted April 4, 2023 I have found that the actual hook to needle timing changes when I sew in reverse on my walking foot machines. While this isn't bad enough to shred the thread, it does occasionally lead to skipped stitches in reverse. You need to really time these reversing machines perfectly, or else... Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
