  • Ambassador
what is the best way to clean my brushes after dying? used 90% alcohol  and murphys soap, but what is the best?
A lot of the time I just use water and paper towel . Rinse well  in water, and clean/dry brushes with paper towel . The paper towel removes pretty much all of the dye, both water based  and alcohol based. Simple.
HS
' I have a very gweat friend in Wome called Biggus Dickus,
He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '  :rofl:
I clean mine in paint brush restorer, then wash in soapy water
I normally just use wool daubers.  They are dedicated to a certain color.  These I keep in a ziploc baggie with the color of the dye written on the baggie in sharpie.  When I use a small brush, I have one of those jars ladies use to remove fingernail polish.  I dip the brush in there, then dab it off on a paper towel.  Works very well.  Something like this...
Maximum Strength Acetone Nail Polish Remover - 9 Fl Oz - Up & Up™ : Target
In God's Grace,
Pastor Bob
"While we were yet sinners, Christ died for us." - Romans 5:8
www.PastorBobLeather.com
YouTube Channel
  • CFM
dish soap and water, wash, rinse until clean and then shape with your spit, let dry.
