Members Davidxy887 Posted April 29, 2023 Members Report Posted April 29, 2023 Hello, Any help is greatly appreciated. I just got a bell skiver and I've been watching a lot of videos to try and set up correctly. Right now its making a weird noise every time i try to feed the leather. Also, the leather does not move at all towards the knife. First I thought maybe there is something stuck so i lifed the wheel and nothing. The wheel is able to rotate completly fine with no weird sound if i dont try to feed the leather. The moment i put a piece of leather there it makes the odd noise. The way I have set it up is that the wheel is less than 0.5mm close to the knife. I have sharpened the knife recently as well. Also, I have tried all kinds of pressure with the foot and nothing helps. What else can I do? Quote
MtlBiker Posted April 29, 2023 Report Posted April 29, 2023 17 minutes ago, Davidxy887 said: Hello, Any help is greatly appreciated. I just got a bell skiver and I've been watching a lot of videos to try and set up correctly. Right now its making a weird noise every time i try to feed the leather. Also, the leather does not move at all towards the knife. First I thought maybe there is something stuck so i lifed the wheel and nothing. The wheel is able to rotate completly fine with no weird sound if i dont try to feed the leather. The moment i put a piece of leather there it makes the odd noise. The way I have set it up is that the wheel is less than 0.5mm close to the knife. I have sharpened the knife recently as well. Also, I have tried all kinds of pressure with the foot and nothing helps. What else can I do? What's the make/model of your skiver? What kind of "weird noise" is it making? Does it sound like metal against metal, against the stone, or what? Maybe you could make a short video and show us? Quote
Members Davidxy887 Posted April 29, 2023 Author Members Report Posted April 29, 2023 4 minutes ago, MtlBiker said: What's the make/model of your skiver? What kind of "weird noise" is it making? Does it sound like metal against metal, against the stone, or what? Maybe you could make a short video and show us? Techsew Sk 4. It sounds like leather against metal i think. Ill try to get a video of it and post it here Quote
kgg Posted April 29, 2023 Report Posted April 29, 2023 1 hour ago, Davidxy887 said: Techsew Sk 4. How thick is your leather that you are trying to skive. From the Techsew site ( www.techsew.com/en/techsew-sk-5-heavy-duty-leather-skiving-machine.html ) " The SK-5 is recommended for leather from 4-5oz and thicker. For thinner leather, we recommend the Techsew SK-4. " kgg Quote
Members Davidxy887 Posted April 29, 2023 Author Members Report Posted April 29, 2023 4 hours ago, kgg said: How thick is your leather that you are trying to skive. From the Techsew site ( www.techsew.com/en/techsew-sk-5-heavy-duty-leather-skiving-machine.html ) " The SK-5 is recommended for leather from 4-5oz and thicker. For thinner leather, we recommend the Techsew SK-4. " kgg Thank you. Yeah its 1mm thick. Quote
Members Davidxy887 Posted April 30, 2023 Author Members Report Posted April 30, 2023 https://youtu.be/UpPfv50kcpk This is a video of the sound it makes. Quote
RockyAussie Posted April 30, 2023 Report Posted April 30, 2023 I can not be sure as the video does not show from the best angle to see the gap between the bell edge and the presser foot but I am thinking that your bell edge is too close to the presser foot edge. This video of mine should help to show that distance I think - Quote
Members Davidxy887 Posted May 1, 2023 Author Members Report Posted May 1, 2023 (edited) On 4/30/2023 at 6:31 AM, RockyAussie said: I can not be sure as the video does not show from the best angle to see the gap between the bell edge and the presser foot but I am thinking that your bell edge is too close to the presser foot edge. This video of mine should help to show that distance I think - Thank you. Now the sound is gone but its not cutting anything. Again im testing it on 1mm leather. Edited May 1, 2023 by Davidxy887 I need a different clarification now Quote
RockyAussie Posted May 2, 2023 Report Posted May 2, 2023 Only thing I can suggest from here assuming that you have moved the bell backward the correct distance is that you have not given it enough of a sharpen yet. Quote
