Members stampingdelight Posted May 23, 2023 Members Report Posted May 23, 2023 I am double checking when painting or dying a leather mask that will have wet molding do I paint or dye before or after I wet mold? was thinking after just seeing if might be doing wrong Quote
CFM chuck123wapati Posted May 23, 2023 CFM Report Posted May 23, 2023 59 minutes ago, stampingdelight said: I am double checking when painting or dying a leather mask that will have wet molding do I paint or dye before or after I wet mold? was thinking after just seeing if might be doing wrong i did one after molding it, used an air brush to apply but i think you could do it either way. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members Dwight Posted May 23, 2023 Members Report Posted May 23, 2023 Depending on how well you want it to fit . . . a light coat of paint . . . like air brush . . . really thin . . . will work. You'll get better looking results if you do the mask first . . . get it all edged . . . lined . . . cut out . . . etc. Then paint the thing. Everytime you wet and try to mold veg tan . . . it remembers some of the time before . . . so if you want it to really fit right . . . mold it first. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
