AlZilla Posted May 28, 2023 Report Posted May 28, 2023 Kind of a long shot here. Does anyone know of a close match to the Tandy Brown Bison Dye that I can buy in a quart or larger size? I ran across the color here, liked it and bought the 4oz size. It seems to take quite a bit to get coverage and it's way too much $$$ to buy in the small size. I can not find anything bigger than the 4 ouncer. Thanks. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
CFM tsunkasapa Posted May 28, 2023 CFM Report Posted May 28, 2023 I've never heard of 'Brown Bison'. Is that one of their EcoFlo products? Quote Hoka Hey! Today, tomorrow, next week, what does it matter?
CFM chuck123wapati Posted May 28, 2023 CFM Report Posted May 28, 2023 35 minutes ago, tsunkasapa said: I've never heard of 'Brown Bison'. Is that one of their EcoFlo products? yes it is i use a lot of it, Bison brown on my bottle. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
CFM tsunkasapa Posted May 29, 2023 CFM Report Posted May 29, 2023 19 hours ago, chuck123wapati said: yes it is i use a lot of it, Bison brown on my bottle. That explains a lot. I quit using Tandy's products years ago. Quote Hoka Hey! Today, tomorrow, next week, what does it matter?
AlZilla Posted May 29, 2023 Author Report Posted May 29, 2023 21 hours ago, tsunkasapa said: I've never heard of 'Brown Bison'. Is that one of their EcoFlo products? Yes. Someone here used it and I liked it. Normally, I don't like brown, but this one is nice. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
AlZilla Posted May 29, 2023 Author Report Posted May 29, 2023 21 hours ago, chuck123wapati said: yes it is i use a lot of it, Bison brown on my bottle. How is your coverage with it? I made 4 purse straps, a half inch by about 2 feet and ate up about a third of a bottle. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
CFM chuck123wapati Posted May 29, 2023 CFM Report Posted May 29, 2023 1 minute ago, AlZilla said: How is your coverage with it? I made 4 purse straps, a half inch by about 2 feet and ate up about a third of a bottle. i usually apply it with either an air brush or a natural sponge. The airbrush if i want a nice even dye job, or with the sponge if i want it to have some variation without streaks and stuff. i have a hard time getting an even job without dipping, never have figured out the dauber so i use the problem to my advantage a natural sponge does a nice job if you just daub or tap it lightly, don't wipe it or smear on the dye just daub it lightly all over. here is a phone case with the dye daubed on. Just now, chuck123wapati said: i usually apply it with either an air brush or a natural sponge. The airbrush if i want a nice even dye job, or with the sponge if i want it to have some variation without streaks and stuff. i have a hard time getting an even job without dipping, never have figured out the dauber so i use the problem to my advantage a natural sponge does a nice job if you just daub or tap it lightly, don't wipe it or smear on the dye just daub it lightly all over. here is a phone case with the dye daubed on. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Doc Reaper Posted May 29, 2023 Report Posted May 29, 2023 35 minutes ago, AlZilla said: How is your coverage with it? I made 4 purse straps, a half inch by about 2 feet and ate up about a third of a bottle. The amount of leather you had to dye was a 2 inches wide by 24 inches long (a good size chunk) and I’m guessing the bottle size is the 4 ounce (.118 liters)? And that you covered all the sides. I’m going by your words, that using 1.3 ounces is about the right amount (Unless you used one third of the 32 ounce bottle = around 10 ounces, which is way too much). I really don’t use my air brushes much and I’m sure the amount used would be about half an ounce, but the finished look would be drastically different Quote Doc Reaper
AlZilla Posted May 29, 2023 Author Report Posted May 29, 2023 2 minutes ago, Doc Reaper said: The amount of leather you had to dye was a 2 inches wide by 24 inches long (a good size chunk) and I’m guessing the bottle size is the 4 ounce (.118 liters)? And that you covered all the sides. I’m going by your words, that using 1.3 ounces is about the right amount (Unless you used one third of the 32 ounce bottle = around 10 ounces, which is way too much). I really don’t use my air brushes much and I’m sure the amount used would be about half an ounce, but the finished look would be drastically different I guess when you look at 2x24" and both sides, it is a pretty good amount of real estate. Maybe I'm just a cheapskate (yes, I am). I'd still like to find something close enough that I could get by the quart. The Bison Brown seems to be only available in the small size. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
AlZilla Posted May 29, 2023 Author Report Posted May 29, 2023 22 hours ago, chuck123wapati said: yes it is i use a lot of it, Bison brown on my bottle. Yes, Bison Brown, not the other way around. Dyslexic fingers ... Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
