Members Constabulary Posted June 22, 2023 Members Report Posted June 22, 2023 (edited) Last thing I need is another zig zag machine but I was looking for a 207D for quite a while cause it is a quite interesting machine. But I wanted one in a better shape and not a barn find again. Will this ever end? Well - when it is for free you just grab it, right? Maybe there must be something addictive in the Singer cast iron The Singer "D" machines were made in Wittenberge, Prussia and I don´t think the 207 model was made anywhere else in the world. It is a beefed up version of the Singer 206 (kind of) but the 207 has a CB hook and no timing belt but seems to have some similarities in the ZZ mechanism. Interesting part here is that it is a CB hook zig zag machine and this (the CB hook zig zag) is AFAIK quite rare among industrial size machines, isn't it? And on top of that for a drop feed machine it has a very very long stitch length (dial say 8mm) especially for a machine of this age (WWII wartime made I guess). Stitch length dial and reverse lever seem to be from the Singer 96. So I think it is worth tinkering a little bit. Not sure where I will end with this... The wooden table base is worm eaten so not worth saving but the plate is still quite good so maybe I´ll keep it. The wooden pedal is cool too but has a lot of surface wear. Machine is bone dry and not spinning at all... Some picture: Edited June 22, 2023 by Constabulary Quote
Members cynthiab Posted June 22, 2023 Members Report Posted June 22, 2023 Hahaha, yes it is an addiction. I think we all share that. That I s an interesting machine.... with an unbelievable amount of dust/ dirt build-up inside. lol Quote
Members shoepatcher Posted June 22, 2023 Members Report Posted June 22, 2023 Nice find C!!! glenn Quote
Members Handstitched Posted June 22, 2023 Members Report Posted June 22, 2023 On 6/22/2023 at 8:24 AM, Constabulary said: Machine is bone dry and not spinning at all Expand why do you keep finding these barn finds ??? not fair Dry as a bone eh ? A shite load of WD 40 will do the trick On 6/22/2023 at 8:24 AM, Constabulary said: Well - when it is for free you just grab it, right? Maybe there must be something addictive in the Singer cast iron Expand Yup, Like 'Pringles' , , ' once you pop, you can't stop ' HS Quote
CowboyBob Posted June 23, 2023 Report Posted June 23, 2023 A rare one for sure,I like the pedal,it does look a bit like the 206.Nice Find!! Quote
Members Constabulary Posted June 23, 2023 Author Members Report Posted June 23, 2023 (edited) On 6/22/2023 at 3:40 PM, Handstitched said: why do you keep finding these barn finds ??? not fair Expand Most folks don´t care about "barn find condition machines" over here and especially not old odd Singers. But that is just what I like. For sure a little bit of a challenge but when I fail it did not cots much - just some bucks for gas and oil and WD40... Today I pulled out (no I hammered it out) the Zig Zag unit. Damn - totally seized up in the casting and WD40 and applying heat did not help much. The ZZ unit housing is aluminum and after siting in cast iron machine for several decades and the machine was sitting in a barn for... I don´t know how long... well that was a quite challenge but seems I did not damage the parts (will figure when it is back in the machine and ZZ is adjusted). The ZZ unit housing needed some good sanding and polishing but it now goes back in fairly easy but it is still tight fitting. I really feared braking it. I just needed quite some force (IMO) to drive it out - that reminded me of my 1st 111G156 when I hammered out the bushing on the hand wheel when I replaced the timing belt.... When I got it sewing and ZZ is working properly I will decide how I will go on with this machine... Edited June 23, 2023 by Constabulary Quote
Members Constabulary Posted June 23, 2023 Author Members Report Posted June 23, 2023 Check spring if fxcked up - lets hope its not and odd one Quote
Members Constabulary Posted June 23, 2023 Author Members Report Posted June 23, 2023 (edited) Found one in my part bins that works. Not sure what the Singer part number is but this one with # 52394 on Ebay looks quite close (just in case some one is looking for one): https://www.ebay.co.uk/itm/385661563974 Edited June 23, 2023 by Constabulary Quote
Members Handstitched Posted June 24, 2023 Members Report Posted June 24, 2023 On 6/23/2023 at 4:51 PM, Constabulary said: Most folks don´t care about "barn find condition machines" Expand From the pics , it doesn't look to bad, condition wise. A bit of surface rust, sure, but that can be cleaned up. Will you give it a new paint job or keep the original patina ? Look forward to seeing the end result. HS Quote
Members Constabulary Posted June 24, 2023 Author Members Report Posted June 24, 2023 (edited) It´s overall not too bad it was just stored under bad conditions for a long time. The underside is very nice - just old dried oil and some dust. I´m a little between the chairs but I think I will repaint it IF it will sew properly. Maybe hammer tone silver and black flat bed. Edited June 24, 2023 by Constabulary Quote
Members shoepatcher Posted June 25, 2023 Members Report Posted June 25, 2023 Nice work C!, glenn Quote
