Members Besthorsegear Posted July 10, 2023 Members Report Posted July 10, 2023 My wife's saddle got hit by a sprinkler, left spots. Tried wetting the area and oil, neither worked. Like Resolene wore off in spots. Any ideas? Thanks! Quote
Moderator bruce johnson Posted July 10, 2023 Moderator Report Posted July 10, 2023 Some saddles are finished with a pigmented topcoat. If water hits it potentially could make it run and show patchy discoloration. It is odd that sprinkler water made the spots but then water didn't change the surrounding area when you applied it. You could try contacting the maker and see what they use for a finish. If they will tell you, you've got more to go on. Otherwise option B - experiment with stuff and option C - ride it and you probably won't know it happened in a year. Sun, oil, and sweat cover a lot of finish blemishes over time. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
Members Handstitched Posted July 10, 2023 Members Report Posted July 10, 2023 @Besthorsegear Yep, thats happened to me a few times on my belts that are on a belt spinner. You're at the mercy of the elements when selling at outdoor venues. And some idiot forgot to turn the sprinklers off at one venue...OOPS!! Anyway, I experimented with a little antique dye , and to try and match the original colour, that seemed to work . That looks like a ' whisky antique' . Hope this helps a bit. HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
Members Besthorsegear Posted July 10, 2023 Author Members Report Posted July 10, 2023 Kinda thought I might end up trying a dye, thanks Quote
Contributing Member fredk Posted July 10, 2023 Contributing Member Report Posted July 10, 2023 Sounds like it was 'hard'water. Have you tried washing it down with a mild dilute distilled vinegar / water solution? Quote Al speling misteaks aer all mi own werk..
Members SUP Posted July 10, 2023 Members Report Posted July 10, 2023 (edited) Mineral oil brings back/refreshes faded color. That might help; either mineral oil on its own or in a mix with a little beeswax. Edited July 10, 2023 by SUP Quote Learning is a life-long journey.
Members bladegrinder Posted July 10, 2023 Members Report Posted July 10, 2023 For starters I’d try a few good rubbings with saddle soap. Quote
