CowboyBob Posted August 9, 2023 Report Posted August 9, 2023 3 hours ago, Teradee said: Thanks @CowboyBob. I stayed up last night and fixed that part and was working on the timing as well. It's running pretty smoothly, but seems to be slightly binding from time to time as I turn the wheel. I'm assuming that is also a timing/alignment thing? I'll be digging in on that later today. Jason When the outside foot lifts it will feel like a "bind" due to the foot pressure on the foot,lift the foot & turn the machine & see how it feels. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Moderator Wizcrafts Posted August 9, 2023 Moderator Report Posted August 9, 2023 Try reducing the pressure screw on the presser foot and see if it is easier to turn the balance wheel. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Teradee Posted August 9, 2023 Author Members Report Posted August 9, 2023 I will definitely give these a try. The one thing that is odd is that when it catches the hand wheel, turns a little while the machine is not turning, which I assume would be the way it would get out of time quickly if I were using it. I will try the presser foot pressure and the screw to loosen it up a little bit and see how it goes! Quote
Moderator Wizcrafts Posted August 9, 2023 Moderator Report Posted August 9, 2023 2 minutes ago, Teradee said: The one thing that is odd is that when it catches the hand wheel, turns a little while the machine is not turning, which I assume would be the way it would get out of time quickly if I were using it. Something has come loose on its shaft. Check every setscrew the attaches the balance wheel to the main shaft and onward. There shouldn't be more than a gazillionth of a parsec of free motion. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
