sportycliff
Chinese burnisher and sander
Good morning,
Does anyone know where I can get sanding drums/belts/sleeves for the cheap Chinese sander/burnisher machines?
Approx 2 3/8" diameter x 2" wide?
I've searched ebay/Amazon/search engine and can't find any other than Tandy, and they're priced out of sight.
I'd hate to have them made if someone is already carrying them in multiple grits.
TIA
Cliff
you may have to convert to mm to find the right size.
i found 2 1/4"
https://woodworker.com/3x4-12-aluminum-oxide-80-grit-spiral-band-mssu-126-221.asp
I have that same model from Amazon,  I haven't used it yet because I have a belt sander and a burnisher I got from the leather tool guy, I'll check the box it came in to see if it has any info
Thanks,
Still looking.
Converting to 60mm didn't work.
Funny, as many of these things that are out there, you'd think ebay and Amazon would be loaded with replacement belts.
That's an odd diameter for a sanding sleeve.  https://www.mcmaster.com/products/sanding-sleeves/  Perhaps you could switch to a standard size sanding drum on your arbor.  I buy sleeves for my Cobra sander/burnisher from McMaster-Carr.  They sell sanding drums as well.
As other have said measure the shaft and get a common sized one that's more available.
Edited by Burkhardt
wrong size
