Ok so I got brave and took off the leather stack handle.   Found out it was just peened over on the end. I think the last washer may have been rawhide by the peened over end Pics tell the story.
I have never messed with rawhide at all.  Debating do I try to get some and redo the mallet head too or just the leather stack.   Open to thoughts.  Gonna clean up the metal parts first regardless.
  • Replies 34
  • Created
  • Last Reply
Top Posters In This Topic
Well it looks like I missed completely  :o
Glad you got it taken apart and I would have to put new  rawhide on the head while it's down .
No I think your assessment on the patent pics was correct.  This appears different.  Maybe a newer or older version.
Now I need to figure out the rawhide!
Edited by Rossr
It would be cool if there was enough rawhide left if you get it compressed and sand it a little. I'd bet the years of hide patina would look great sanded and resealed.
I think I can reuse what is there. It's till pretty tight and when I did some light sanding  on it before I took it apart didn't seem bad.  The fact I don't have any rawhide in my shop leads me to think about reusing too
Ross
  • 3 weeks later...
Ok so cleaned it up some and decided to save the rawhide as is.  So here is where I'm at. Leather handle will be next.   I'm tempted drill and tap the end and screw the leather fast with a metal washer rather than peen it again. Thus allowing it to be taken apart again if needed.
Looks like it is cleaning up nicely . Looking forward to seeing it when ya get her done !
  • CFM
that will be soooo cool! great job so far.
So added the leather I'm now debating 1.  Do I nees to epoxy or glue each one. Which seems crazy and a lot of glue or epoxy. 2.  Do I just drill tap add Washers and a bolt of some type or Allen head screw. Hmmm
Anyway got the leather rings on it.
