20231104_011857.thumb.jpg.67dc7e314d48f11034cf387a9709fa0b.jpgI had a leather shop for about four years after I left the military in 1968. I made hundreds of pairs and loved it. I was a poor businessman, though, and I went on to other things. After a career in remodel contracting I have returned to sandal making. The past 12 months I have spent ten grand buying what I need for another sandal shop. I should launch production in one month.
The shop is in my apartment and there is someone living under me and someone across the hall.  When I glue the soles together, I don't want to hammer them when the glue is sticky, like I used to do, out of consideration for my neighbors. I can't find a manual press for helping the glue bond. I need something that can press between straps, along the edge of the sandals. It will need a longish handle. I won't something that can press every spot on a sandal quickly, thus handle- operated is a must. I also wonder if I'm using the right kind of leather for the soles and straps. I can't find anyone who's making leather sandals and who might be willing to share information. My name is Patrick, my product will be custom leather sandals of my design, machine stitched, no strap between the toes, straps are fully adjustable, and there's a gum rubber bottom. I haven't made a pair yet but I have a sketch.  I have to build my website in the next month with ecommerce store. I'm starting with just one design of sandals, which I developed over this past 12 months. I made about 15 designs my first time around. I'll probably make others, especially if requested. I'm using shoulder for top sole.
This might work using the selfie camera. 20231104_011857.thumb.jpg.67dc7e314d48f11034cf387a9709fa0b.jpg
Harbor freight sells a half ton or one ton arbor press . . . a tad heavy . . . will need bolted to a table top or something . . . but with a larger flat surface . . . and a piece of 2 by 6 that you fashion to slip into the straps and lay flat along the top piece . . . you can put some serious "quiet" pressure on the thing.
If you've never used one . . . that little round table comes off . . . giving you a place to lay a piece of 2 x 6 . . . add the sandal bottom . . . slip in the formed piece for the top . . . pull down on the handle . . . voila . . . done.
https://www.harborfreight.com/1-ton-arbor-press-59766.html?ccdenc=eyJjb2RlIjoiMTcyMDQ4MTIiLCJza3UiOiI1OTc2NiIsImlzIjoiNjIuOTkifQ%3D%3D&utm_source=google&utm_medium=cpc&utm_campaign=20737678297&campaignid=20737678297&utm_content=156191151498&adsetid=156191151498&product=59766&store=3113&gclid=CjwKCAjw15eqBhBZEiwAbDomEobTEjJnQG46i4KEr6GpH-siVkskQNeWXaUPPHRZdlGB2RDMXPCI8RoCYrcQAvD_BwE
May God bless,
Dwight
www.dwightsgunleather.com
  • CFM
I've always wondered if one of these would work for glue ups.https://www.amazon.com/Calliger-Crank-Clothes-Wringer-Rollers/dp/B00OAPW6GM
Lisa Sorrell sells a sole press. Its designed to be used with lasts, but you could cut a sandal sole shaped piece of plywood in the sizes you make.  It has a small foot print so it would be eating up space  in your apartment.
https://sorrellnotionsandfindings.com/product/sole-press/
May God bless,
Dwight
I think this might work! Thanks!
There's the problem of straps sticking up out of the topsole... plus I think this thing might displace the soles from each other, because it is essentially pushing away as it squeezes. I need the force to be only perpendicular to the topsole, pressing it into the mid and bottom soles, although i will be doing it in  two parts. First, press the top into the midsole, then the mid into the bottom. Thanks for the suggestion!
Al Bane sent me that link, too. I don't use lasts, as the sandals are flat, not wrap around the foot type. And I need just one point of downward pressure, without foam pads under the sandal. I need an ungiving surface below the sandal. I think I can work with the Harbor Freight press, mentioned by Dwight. I can make something that will press into the top sole to help the glue bond. I'll probably use a piece of white oak, sanded smooth, unless I can find something made of steel. thanks for your suggestion!
Have you ever researched the way the Romans of Roman Empire days did their sandals for their troops?
I have a full Roman centurion rig I use in church for plays . . . etc.  They made their sandals out of a sole . . . then a piece that became the toe, heel, and side, . . . and then an inner sole above it.  All together . . . 3 layers of leather . . . and I made mine to complete the uniform.
Some day when I have nothing better to do . . . I'm going to make another pair which will be for me to actually wear . . . and I'll probably make them "high top" . . . as I have neuropathy in both feet . . . cannot stand a boot or anything that rubs my ankles . . . but I want something to keep the feet warmer than the Sketcher low cut athletic shoes.
May God bless,
Dwight
https://en.wikipedia.org/wiki/Caligae
May God bless,
Dwight
Those things look heavy and uncomfortable, and they look aggressive, scary, and yeah, ugly. I'm hoping my sandals will be stylish, light, minimalistic, beautiful- looking, and that people will buy them to wear to church. My design is so that folks can wear socks with them. I'm almost ready to make a first prototype, maybe within the month. My idea is to make the leather gorgeous, and the design functional. I have five people lined up to test drive a pair, give feedback, in exchange they keep the sandals, or if a modification is needed, then they will get a working pair. I call them my product development team. 3 of them have lifetime issues with uncomfortable and ill- fitting footwear, which is why I selected them for the team.
As one with foot issues . . . thank you for selecting them . . . look forward to seeing more here.
May God bless,
Dwight
