Members FizzyWizzy Posted November 9, 2023 Members Report Posted November 9, 2023 Hello, I am a newby to leather sewing machines. I am buying an Adler Cylinder Arm 49-2 and would love more information on it. I have been searching the net but no luck. Looking to see if Singer made an equivalent. Looking for a manual. And looking for any opinions. I have attached a picture.TIA Quote
Members Constabulary Posted November 9, 2023 Members Report Posted November 9, 2023 Singer 18-3 is the equivalent Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
kgg Posted November 9, 2023 Report Posted November 9, 2023 9 hours ago, FizzyWizzy said: And looking for any opinions. First off what are you planning on sewing? This machine is a right handed machine rather then the typical left handed machine, parts are going to be expensive, if they are still available. Looking at the photo it appears to have a clutch motor and for better sewing control you will need to replace it with a servo motor about $200 Cad. What is the asking price? If this is going to be your only or first machine I would look at other options. What part of Ontario are you located? kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Uwe Posted November 10, 2023 Report Posted November 10, 2023 (edited) Yep, it appears that the Singer 18 class is very similar, and @Constabulary beat me to it and very likely knows more about it than I do. I also would recommend staying away from this model as a first machine. It may be a great machine and all, but it’s such an oddball machine that you’re essentially on your own figuring it out. At the same time, it may be valuable in a collector sense, since it’s such a rare vintage machine. Here’s a manual I found for the Singer 18 class: class_18.pdf The images below are the only manual I could find for the original Adler 49. Unfortunately the good soul who photographed them wasn’t very good at it, so the quality is rather poor. It’s also in German. But it may be better than nothing. Edited November 10, 2023 by Uwe Quote Uwe (pronounced "OOH-vuh" ) Links: Videos
Members Constabulary Posted November 10, 2023 Members Report Posted November 10, 2023 (edited) its rather a light duty machine for the shoe trade f.i. for sewing shoe uppers. Its not that you cannot sew other things on it but that is what the machine was designed for. The bobbins are fairly small. I have a Singer 18 brochure (see attachment). The Singer 18-3 or Adler 49-2 are quite the same as the Class 18 shown in the brochure with the difference of having wheel feed instead of a feed dog. Let us know what you are planing to sew (material thickness, product....) so I´m sure we can recommend a machine for your needs. Singer 18-22 Broschüre.pdf Edited November 10, 2023 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members FizzyWizzy Posted November 11, 2023 Author Members Report Posted November 11, 2023 On 11/9/2023 at 7:05 AM, kgg said: First off what are you planning on sewing? This machine is a right handed machine rather then the typical left handed machine, parts are going to be expensive, if they are still available. Looking at the photo it appears to have a clutch motor and for better sewing control you will need to replace it with a servo motor about $200 Cad. What is the asking price? If this is going to be your only or first machine I would look at other options. What part of Ontario are you located? kgg Thanks. Appreciate the comment about it being a right handed machine. It has a roller foot and a speed reducer. The price is $700. It would be my only machine for leather. I have a Pfaff sewing machine and a Juki server. I am located in Bobcaygeon. Quote
Members FizzyWizzy Posted November 11, 2023 Author Members Report Posted November 11, 2023 @Uwe thank you for all your info and the copies of manuals. Quote
Members FizzyWizzy Posted November 11, 2023 Author Members Report Posted November 11, 2023 19 hours ago, Constabulary said: its rather a light duty machine for the shoe trade f.i. for sewing shoe uppers. Its not that you cannot sew other things on it but that is what the machine was designed for. The bobbins are fairly small. I have a Singer 18 brochure (see attachment). The Singer 18-3 or Adler 49-2 are quite the same as the Class 18 shown in the brochure with the difference of having wheel feed instead of a feed dog. Let us know what you are planing to sew (material thickness, product....) so I´m sure we can recommend a machine for your needs. Singer 18-22 Broschüre.pdf 1.06 MB · 2 downloads Thank you for advising its design purpose and that it is not intended for heavier work. I was concerned about that but had not been able to find the pertinent info on the net. All of the comments have convinced me to not follow through with the purchase. Thanks. I am wanting to make bags in particular. The cylinder arm seemed to be good for maneuvering around right corners and three dimensional objects. Tomorrow I will measure the leather I have and provide the range in this post. Thanks again. Quote
kgg Posted November 11, 2023 Report Posted November 11, 2023 (edited) 12 minutes ago, FizzyWizzy said: The price is $700. It would be my only machine for leather. If I was looking for an old machine that was an oddity I would probably consider purchasing it as a keep sake. If I was looking for a something that would be a main stay machine with inexpensive parts / attachments I would not consider it. Without knowing what you are planning on sewing it would be hard to give any suggestions as to what machine would be able to do the task???? wallets, belts, bags, holsters, leather over 3/8" thick. Also what is your budget?? kgg Edited November 11, 2023 by kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members FizzyWizzy Posted November 11, 2023 Author Members Report Posted November 11, 2023 21 minutes ago, kgg said: If I was looking for an old machine that was an oddity I would probably consider purchasing it as a keep sake. If I was looking for a something that would be a main stay machine with inexpensive parts / attachments I would not consider it. Without knowing what you are planning on sewing it would be hard to give any suggestions as to what machine would be able to do the task???? wallets, belts, bags, holsters, leather over 3/8" thick. Also what is your budget?? kgg Bags is my main focus but also belts and smaller items like wallets. I also would like to use it for upholstery projects. I wouldn't be looking to go over 3/8" even with two layers of leather. And my budget LOL I was hoping under $1000 but I also realize that I want the right machine for the job so I had better increase that to $2000. Quote
