Members Mulesaw Posted December 29, 2023 Members Report Posted December 29, 2023 Using the fantastic instructions given by @TomE, I made another double stitched halter for Gustav's girlfriends new horse for Christmas. For some reason they prefer a double stitched halter to a triple stitched, so I give them what they want. This one I made the rolled throatlatch a bit thicker by adding a double filler. The last black one I made was a bit harder to do than the brown ones, It was like the leather was harder, so to overcome that I inserted a thicker filler, and it made it easier. I have also engraved a name tag for the halter, just like I did on the last halters that I have made. The name tag was sewn on after these pictures were taken. The horse's name is Ocean X Quote
Members DieselTech Posted December 29, 2023 Members Report Posted December 29, 2023 Beautiful looking piece. Great work. I hope to get into making stuff like that someday. Thanks for sharing. Quote
Members TomE Posted December 30, 2023 Members Report Posted December 30, 2023 That's a beauty, @Mulesaw! Looks like the rolled throatlatch turned out nicely. I like the contrasting color on the thread. Quote
Members Mulesaw Posted December 30, 2023 Author Members Report Posted December 30, 2023 @DieselTech thanks for the kind words. Horse related stuff is usually well received by horse owners. So if you would like to make something like it, A halter is really a good place to start, since most horse owners use halters of some kind. It is a doable project, even by hand stitching, but it takes a bit of time. But then again - if you have made it correctly, the halter will last for the next 50 years or so. @TomE Thanks, I follow the instructions given by Gustav :-) And he likes that the stitches are visible. He got his journeyman's certificate as a carpenter this fall, but he has accepted a job as jumping rider at a stable called ESH sport Horses, I don't think the have a net page, but they are on IG. When I visited him he showed me that the head rider also had a triple stitched halter, something Gustav had never seen save for the first one that I made. I am planning on making a stallion halter based on a model that I borrowed from Katrinelund (the local large stallion station) I'll try to make some instructions for it to post here when I get it done. It is a heavy type halter with doubled leather all the way round The throatlatch and the noseband are both in one piece 5/4" wide. The cheek pieces are fastened through a slot in those. So the only hardware is a Ring in the bottom of the nose band. And 3 buckles. one for each cheek piece and one for the throatlatch/neck piece. According to the owner of Katrinelund it is an old model that he had an old saddlemaker make for them years ago. And I can see the idea in it. It isn't a particularly pretty halter but it does a specific job, and it is virtually impossible for the stallions to loose the halter or to tear it apart. Quote
Members TomE Posted December 30, 2023 Members Report Posted December 30, 2023 4 hours ago, Mulesaw said: I am planning on making a stallion halter based on a model that I borrowed from Katrinelund (the local large stallion station) I'll try to make some instructions for it to post here when I get it done. It is a heavy type halter with doubled leather all the way round The throatlatch and the noseband are both in one piece 5/4" wide. The cheek pieces are fastened through a slot in those. So the only hardware is a Ring in the bottom of the nose band. And 3 buckles. one for each cheek piece and one for the throatlatch/neck piece. According to the owner of Katrinelund it is an old model that he had an old saddlemaker make for them years ago. And I can see the idea in it. It isn't a particularly pretty halter but it does a specific job, and it is virtually impossible for the stallions to loose the halter or to tear it apart. Congratulations to Gustav! I once saw a comment that Western saddle making is more like carpentry than leatherwork. I'd enjoy seeing the stallion halter and your rendition of it. Quote
