8 hours ago, fredk said:
2.6mm to 2.8mm bestest
Yup:yes:  , I have tried molding thicker leather but its too hard on my hands these days.
HS
' I have a very gweat friend in Wome called Biggus Dickus,
He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '  :rofl:
HS
That's basically 7/8 oz . . . my usual holster making material . . . I double it . . . contact cement the two together . . . and mold the holster from that.
I also make a lot of other stuff out of it . . . probably my favorite thickness . . . makes great CCW or cartridge belts . . .
Vacuum forming rig helps out.
May God bless,
Dwight
www.dwightsgunleather.com
The 3mm  is often my ' go to ' thickness for molding , sometimes 3.5 mm .
I must have a bit of ' Arthur Ritis ' in my hands these days. :blush:
HS
On 2/4/2024 at 3:09 PM, Dwight said:
I buy from Tandy . . . have no complaints on the stuff I've gotten from them.
Yes, I use it all the time too and it works fine for me as well. The only complaint I have about it is that it does not usually  stain well with Vinegaroon - turns a dull grey.  @ToddW, if you plan to dye your leather with that, maybe you could test a piece first.
Learning is a life-long journey.
