Very little of the needlebar.org site works.
Ken
There are a lot of things that can cause mis stitching on these machines. I would like to see a close up picture of your thread path around the top tension discs and how you have the thread up  to the take up lever. I can not see any adjuster for the thread take up lever on your machine but that may be just the picture.
YouTube Channel
Instagram
  • 3 weeks later...
Rocky,
I bring the thread from the grease cup, around the peg on the top of the head, then around the tension disks, then through the wire loop, then up and through the take up lever from the front, then down the shaft to the needle.  There is no adjustment for the take up lever as you can see in picture number 3. Hope the pictures help.
Have you inspected the paddle shaped thread control spring in the needle bar? It is slightly visible from the left side when you lower the needle bar to BDC. The top thread feeds through that spring. Its job is to hold the thread in place as the needle makes its down-up-down jog. After decades of use that spring may have been gouged by thread, or just weakened, or even became twisted, thus no longer able to press firmly against the thread to hold it in place. Sometimes, the thread even gouges a channel into the needle bar, behind the spring, causing it to have little effect on the thread security. Without that spring, the loop tends to dissolve before pick-off time.
Bob Kovar usually stocks the paddle springs and the tiny screws that secure it to the needle bar. He might even have a complete needle bar with the paddle spring attached. Replacing the spring calls for removing the needle bar. So, you may as well try to find a newer bar, complete with the paddle spring and a new needle clamping bracket.
If Bob doesn't have the parts, @shoepatcherprobably does. I get patcher parts from him too.
Posted IMHO, by Wiz
Has not to do with picking up the thread but what I noticed is that your Singer 29K51 has an arm lever from a very early Singer 29 that lacks the the adjuster for the thread take up lever. IIRC only the very early 29 came w/o this adjuster so your machine should have the adjuster shown in the below picture. However it should pick up the thread w/o this adjuster.
How is the condition of your shuttle hook, has it a sharp tip? Also, the needle holder can be moved sideways to bring the needle a bit closer to the hook.
Have you probably taken apart the gear box and not reassembled it correctly? That happens and the "drop out" gear box of the 29K51 is a bit special. I have restored only one single 29K51 (no longer own it) and there was no instructions for how to reassemble the gear box again so I did some trial and error and ended with the gear box and rack assembled like this - see 2nd picture - and it worked.
BTW - do you have manual for your machine?
One more question - how far did you take down the machine? Did you remove the top shaft or any of the cams on the top shaft?
grafik.png.64a5faf6f9f7c742dffedfba0125d9cd.png2046989280_29K5xGearBox.thumb.jpg.c8872a92dc9810b0ff40528a97a7036c.jpg
Edited by Constabulary
How strong should this spring be? On my original, a channel was made by the thread. I ordered an aftermarket spring, which is apparently half as weak (even the thickness of the material is half of the original). It also took quite a bit of sanding to get it in place. I haven't tested it yet as I have quite a few other pieces to fix before then. Thanks!
You have to grind the sides of the spring down so they do not stick out past the outside diameter of the needle bar.  I assume that is what you mean by a lot of sanding.  Also file down the grove in the needle bar cut out if here is a thread grove worn in it.
glenn
glenn
Yes, I mean grinding. English is not my language. I was fix that shape and all parts is inside of needlebar diameter. But I don't know if the spring is strong enaugh. It is much weaker than original.
not a too big issue, the spring just "holds" the thread. It should work with a weaker spring if not I may have a better one (I´ll email you later)
Yes, I had the needle bar out and the spring removed all for cleaning.  The spring holds the thread fine.  Also, I did not remove the cross shaft, but cleaned the gears from the inspection holes.  Haven't done anything with the machine now for a couple weeks...other projects to do.  I did adjust the needle holder sideways but I think I need to do more with that.  Will post results when I get to it.
Thanks for all the thoughts.  I am open to considering anything.
