Members Mablung Posted February 26, 2024 Author Members Report Posted February 26, 2024 6 hours ago, DieselTech said: I have only used the fiebings pro dye a few times, but I noticed that the dyed piece/project seemed to be a slight narrower than originally cut after it dried. I'm wondering if the leather shrinks a bit from dying? I was dip dying. I think this was just a result of my not measuring generously enough and then taking it down too far when trimming before stitching. I think sometimes times do shrink just a bit after dying, but not enough to create quite this issue, at least in my experience. Quote
Members Mablung Posted March 6, 2024 Author Members Report Posted March 6, 2024 (edited) All but final trimming and edge work done. The stitching is atrocious, as I experimented with using my chisels as a pricking iron and finishing the holes in the cover flaps with my awl. My goodness the stitching process was tedious and time-consuming, absurdly so. But I learned a bunch of valuable lessons in making this thing. Looking forward to finishing it and putting it to use. Color is wrong in the photo, but I’m too tired to fiddle with the pic. It’s more of a medium brown and not nearly as yellow as it appears. Edited March 6, 2024 by Mablung Quote
Members dikman Posted March 6, 2024 Members Report Posted March 6, 2024 I'm assuming you handstitched it and with the stitches being so small I'm not surprised you found it tedious! Hard to tell from the photo but if it is "splotchy" it still doesn't look too bad and it should help it get the used look a bit quicker. What I've found is if the leather is just given a coat of NFO and then left in strong sunlight for a couple of days it turns a lovely light brown that is hard to get using dye, it seems to have a lustre that you don't get with dying. As for it not being the right size, yep, been there done that! Just think how much you've learned doing this, the next one will be much better - but this one still looks good, it has that old hand-crafted look about it. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members MarshalWill Posted March 6, 2024 Members Report Posted March 6, 2024 (edited) Looks good. I agree, larger stitches would make it a lot less tedious. I would probably do something like 5 stitches per inch. Certainly no smaller than 6 on this piece. To get an even dye job on light colors, I give the leather a coat of alcohol first. Then I apply the dye. Alternatively, I dip the whole piece in a diluted batch of dye, but that takes a lot of dye to do. I use solvent based dyes, generally Fiebings or occasionally Lincoln. That said, sometimes I purposely make a piece blotchy to give it visual texture. When there's a lot of un-decorated space like yours, that can be nice. I look forward to seeing your next one. Edited March 6, 2024 by MarshalWill Quote
Members Mablung Posted March 6, 2024 Author Members Report Posted March 6, 2024 Yeah, hand stitched. I didn’t fully appreciate just how small the stitches are until I looked at the first major line on this thing. Good grief. I used a set of Craftool Pro Fine stitching chisels I have, I think the 3mm ones. I like the narrow holes because they close up well, compared to my regular Craftool chisels. But man do the holes make it difficult to pull a large-eye needle threaded with 0.8mm Ritza thread through. I learned the benefit of using a stitching awl to stretch the holes. (After I made a real pudding of my stitch lines along the long seams of the cover flaps, but that’s a different set of photos.) Anyway, because I’m a glutton for punishment, I’ll make another soon that will fit my larger notebook. I’ll post that one, too. Quote
Members Mablung Posted March 7, 2024 Author Members Report Posted March 7, 2024 Couple shots of the vertical edge stitching and finishing. At a couple points it’s truly atrocious. But the rest actually looks halfway decent on the exterior. Quote
Members dikman Posted March 7, 2024 Members Report Posted March 7, 2024 I see what you mean! Just a thought, do you have a domestic sewing machine? I started off with an old Singer hand-crank and used it without thread to pre-punch the holes in things like notebook covers, then went over them with an awl and handstitched. This gave me nice evenly-spaced straight stitch lines. Just think how good your next one will be. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Mablung Posted March 7, 2024 Author Members Report Posted March 7, 2024 12 hours ago, dikman said: I see what you mean! Just a thought, do you have a domestic sewing machine? I started off with an old Singer hand-crank and used it without thread to pre-punch the holes in things like notebook covers, then went over them with an awl and handstitched. This gave me nice evenly-spaced straight stitch lines. Just think how good your next one will be. I do not, though I have been considering getting a machine. Not in the budget for a a bit yet, but it sure would make things easier. Quote
Members Mablung Posted March 10, 2024 Author Members Report Posted March 10, 2024 Finished product. Antiquing isn’t great, partly because I started applying the SuperSheen topcoat too soon and smeared the antique paste a bit. But it still turned out pretty sharp, I think. Left the closure tab raw because I’ll rebuild this thing eventually. It’s been put on a smaller notebook than the one I carry for sermons on Sundays. Quote
Members MarshalWill Posted March 10, 2024 Members Report Posted March 10, 2024 I like the subtle antiquing you ended up with. It came out fine. Congrats. You say you'll rebuild it. In what manner? Why not just dye the tab and be done with it? Quote
