Members Hags Posted March 4, 2024 Members Report Posted March 4, 2024 I play golf, so when Don Gonzales came up with this pattern, I had to try it. I made a couple of changes, I used a strap instead of a clip to better go around a push cart frame, and opened up the bottom to make squeezing a ball out easier. Go easy on my tooling, still learning that part. Quote Not so retired RN. Living on the Washington Peninsula.
Members Simplejack1985 Posted March 4, 2024 Members Report Posted March 4, 2024 Nice work. I don't golf but I've wanted to make one. Quote
Members DieselTech Posted March 5, 2024 Members Report Posted March 5, 2024 Looks good. Great work. Does that hold 3balls? & where do you strap it? Thanks. Quote
Members Hags Posted March 5, 2024 Author Members Report Posted March 5, 2024 The pattern calls for a snap. This, IMHO, limits where you can attach it. The strap allows you to go around the tubing of a push cart that carries your bag. You can still attach it to your bag if you want. It holds 4 balls. Thanks for the kind words. Also, opening the bottom allows the balls to come out much easier. Quote Not so retired RN. Living on the Washington Peninsula.
Members DieselTech Posted March 5, 2024 Members Report Posted March 5, 2024 15 minutes ago, Hags said: The pattern calls for a snap. This, IMHO, limits where you can attach it. The strap allows you to go around the tubing of a push cart that carries your bag. You can still attach it to your bag if you want. It holds 4 balls. Thanks for the kind words. Also, opening the bottom allows the balls to come out much easier. How does the opening on the bottom work. Is it some what friction fit where you can squeeze the ball out the bottom. Thanks. Quote
Members Hags Posted March 5, 2024 Author Members Report Posted March 5, 2024 Yes, you can squeeze a ball out of the bottom. It originally was a straight slot, but that took a lot of pressure to pop a ball out. I took a large corner punch and opened it up to make it easier. Quote Not so retired RN. Living on the Washington Peninsula.
Members DieselTech Posted March 5, 2024 Members Report Posted March 5, 2024 17 minutes ago, Hags said: Yes, you can squeeze a ball out of the bottom. It originally was a straight slot, but that took a lot of pressure to pop a ball out. I took a large corner punch and opened it up to make it easier. Thanks. I appreciate you explaining it to me. I'll have to try & make 1. Quote
