Members thekid77 Posted April 20, 2024 Author Members Report Posted April 20, 2024 On 4/19/2024 at 8:00 AM, Aven said: Since linen is a natural product, it will dry out and/or rot. Shoemakers (cordwainers) would use hand wax (coad) on the threads. They had two different types, hard for summer (hard enough not to be a mess in the heat) and soft (so it would work into the threads) for winter. There are few threads on coad. Sorrell Notions was the one place I knew of to find it, but it looks like Lisa isn't carrying it any longer. You'll might have to make your own. JCUK is spot on about using the correct size hole with the correct size thread. You want a hole that will get plugged if you will with the wax on the thread. While sewing with the thread, once and done won't work. With each pull through a hole, the wax is scrapped off a bit, so you will need to rewax the thread as you sew. If your hole/thread size is correct, back stitching will hold it. And if you waxed your thread enough, no glue will work. It can't get to the thread because its coated with wax. Thank you Aven!
