I just picked up an IMMACULATE Singer 29k-71 and the feed foot won't pull the work through. If I pull it, it goes to the appropriate length and stops, but there is no power going to make the foot pull the work through. Any help is appreciated.
@Dannyofalltrades
Your video was uploaded in a file format that's not recognized by our board software and cannot be displayed. Please re-save the photo as a .jpg or a .png and re-upload it. Use a small enough resolution to keep the file size under the forum limit. I find that 1:1 and 3x4 produce suitable small size photos.
Posted IMHO, by Wiz
Above the foot, there should be a stitch length screw/clamp. It slides up and down the feed bar. All the way down to full feed, up for zero.
  • 3 months later...
Hello, just signed up.
anyway I have a Singer 29k62 that I picked up that is having the same problem!  Did you ever find a solution?
The O.P. hasn't responded since he posted this, on April 14, 2024. I suggest that you start your own topic. If you upload photos, keep them as small as possible and in .jpg format.
Posted IMHO, by Wiz
the stitch length clamp is not on properly.  Will not feed because of that.
glenn
  • 2 weeks later...
I will start a new thread as suggested above, I am for sure missing the little wedge that slots into the back of the stitch length clamp on the foot leg(?).  However when I feed it through by hand stitches are so numerous that it basically perforated cardboard for easy tearing.  May start making my own stamps!
