toxo Posted April 28, 2024 Report Posted April 28, 2024 (edited) Does anyone have an English user manual for this motor? It came with my new machine which is a copy of the Techsew 2750. The motor seems ok and I can get it to start really slowly and speed up on the treadle but apparently it has a needle up and a needle down setting. It came with a normal NPS as well but I can't get that to work properly because the machine has a speed reducer. If someone was really good on this machine they could almost get the needle up/down on the treadle but I can't do it with any consistency. The user manual for the motor is mostly Chinese and the English bits just make me laugh. Any advice anyone? Edited April 28, 2024 by toxo Quote
Members fibersport Posted April 28, 2024 Members Report Posted April 28, 2024 You most likely will not be able to get the needle postioner to work with a speed reducer. The simple reason is a needle postioner reads the location of the input shaft of the machine, it is programmed for a particular distance per revolution. With a speed reducer, that distance per revolution is now changed, the positioner is not designed for the change and therefore can't work. Quote
toxo Posted April 28, 2024 Author Report Posted April 28, 2024 19 minutes ago, fibersport said: You most likely will not be able to get the needle postioner to work with a speed reducer. The simple reason is a needle postioner reads the location of the input shaft of the machine, it is programmed for a particular distance per revolution. With a speed reducer, that distance per revolution is now changed, the positioner is not designed for the change and therefore can't work. I appreciate that but the blurb seems to be saying that the motor is capable of needle positioning on it's own. If you look at the picture the two dots above the "P" are for needle up and needle down. I like having needle positioning. On my other two machines I've replaced the handwheel with a larger pulley to slow down the machine which it does very well as well as giving more torque and the normal NPS works very well on both. I wonder if the normal NPS would work on the motor pulley? Quote
1hp Posted April 28, 2024 Report Posted April 28, 2024 (edited) the servo on my Cobra 4 looks same. Edited April 28, 2024 by Northmount Rotated pictures so top is at top and re-uploaded Quote
toxo Posted April 28, 2024 Author Report Posted April 28, 2024 4 hours ago, 1hp said: the servo on my Cobra 4 looks same. Thanks for that 1hp. I'd kinda figured out that much but was thinking was there more to the first part where it talks about needle up/down. Is it saying the motor can do this or only in conjunction with a traditional NPS? Here's what mine looks like. Quote
1hp Posted April 28, 2024 Report Posted April 28, 2024 (edited) not sure as i do not have an NPS. there are outlets for connecting one though. Leather Machine Co. does sell a class 4 with NPS & speed reducer. Edited April 28, 2024 by 1hp more information Quote
Members dikman Posted April 28, 2024 Members Report Posted April 28, 2024 Some NP's will work with a speed reducer, but in most cases you won't know until you try it. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
toxo Posted April 28, 2024 Author Report Posted April 28, 2024 52 minutes ago, dikman said: Some NP's will work with a speed reducer, but in most cases you won't know until you try it. I think I'm gonna try to fit the normal NPS onto the motor pulley. The machine is perfectly usable and will get better as I get used to it but I do like my NPSs. Quote
1hp Posted April 29, 2024 Report Posted April 29, 2024 i put a 40mm pulley on the Cobra 4 motor. in conjunction with the speed reducer, it will go really slow. Quote
Members dikman Posted April 29, 2024 Members Report Posted April 29, 2024 3 hours ago, toxo said: I think I'm gonna try to fit the normal NPS onto the motor pulley. The machine is perfectly usable and will get better as I get used to it but I do like my NPSs. It will be fair bit of messing around but worth a try. I don't think anyone has fitted one to the motor before so it will be an interesting experiment. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
toxo Posted April 29, 2024 Author Report Posted April 29, 2024 3 hours ago, dikman said: It will be fair bit of messing around but worth a try. I don't think anyone has fitted one to the motor before so it will be an interesting experiment. Maybe not. Depends on how much thread is sticking out past the securing nut. The aluminium boss that the nps slides onto is hollow. Don't have a lathe anymore but I'll give it a try. Quote
Contributing Member Samalan Posted April 3 Contributing Member Report Posted April 3 It doesn't matter whether it's slow or fast. The EPS is connected to the sewing machine shaft; it could make one revolution per day and still work. My machine is so slow that I get nervous watching it, and the EPS works just fine. Quote
Members friquant Posted Thursday at 05:05 PM Members Report Posted Thursday at 05:05 PM On 4/28/2024 at 7:11 AM, toxo said: Does anyone have an English user manual for this motor? It came with my new machine which is a copy of the Techsew 2750. The motor seems ok and I can get it to start really slowly and speed up on the treadle but apparently it has a needle up and a needle down setting. It came with a normal NPS as well but I can't get that to work properly because the machine has a speed reducer. I have the same servo motor. The paper manual shows the wrong values for the P15 settings. On mine P15 actually needs to be set to "0" to enable the needle position sensor. Here are my notes on this servo motor, which may reasonably constitute an English user manual, with some missing pieces. Quote
toxo Posted 6 hours ago Author Report Posted 6 hours ago On 6/19/2025 at 6:05 PM, friquant said: I have the same servo motor. The paper manual shows the wrong values for the P15 settings. On mine P15 actually needs to be set to "0" to enable the needle position sensor. Here are my notes on this servo motor, which may reasonably constitute an English user manual, with some missing pieces. Since setting up my machine I've got it working so I can use it easily and so haven't look at the finer details but I have to say something that's on my mind before I forget it. If you take the cover off the normal NPS there are two serrated discs and they have gaps in them which stops the motor. You can get the needle where you want it and then turn the disc to suit. One disc for needle up and one disc for needle down. I used this method for a long time until I got this new one which has a speed reducer. What I've said here doesn't seem to work with speed reducers but if yours doesn't have one it might be worth a look. Quote
