Members Michiel Posted September 11, 2024 Members Report Posted September 11, 2024 I recently bought an adler 205-370 and would like to buy a moving binder set. Kwok Hing offers one for the juki 441 but they claim it also fits the adler 205. https://www.khsew.com/index.php?route=product/product&product_id=1902 Is that possible? are feed dogs and needle plate for the juki 441 and adler 205 Exchangable? Thanks in advance Michiel Quote
Members Constabulary Posted September 12, 2024 Members Report Posted September 12, 2024 (edited) I would not say it is is impossible. When you go back in the history of these machines then it all started with the singer 45K, then later Adler 5, Adler 105 and the needle plates and feed do were interchangeable only difference I noticed is that the feed dog have different length oval screw hole. I´m using an Adler 5 needle plate and feed dog on my Singer 45D91 I only had to alter the feed dog hole a bit to make it work. Sure the machines 441 and 205 are later / more modern machines but Juki´s have a lot in common with the Singers and the 205 is the later version of the 105 so I would not say it is impossible but I have no direct comparison. Just my 2 cents... EDIT: 2 more cents: Since they are the manufacturer of this device I´m almost certain that they have tested this set before they claim that it works for other machines too. Edited September 12, 2024 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
kgg Posted September 12, 2024 Report Posted September 12, 2024 (edited) 16 hours ago, Michiel said: Is that possible? There is a couple of links to video's of the moving arm. I assume there are specific feed dogs and needle for each machine. i) https://www.facebook.com/khsewing/videos/how-the-moving-arm-working-in-binding/554470568589194/ ii) https://www.facebook.com/100064388931666/videos/223974593051605/?__so__=permalink Unless you are going to turn the machine into a dedicated edge binding machine it seems to me like a lot of extra work just to do edge binding and then have to strip it down to do regular sewing. kgg Edited September 12, 2024 by kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Michiel Posted September 12, 2024 Author Members Report Posted September 12, 2024 9 hours ago, Constabulary said: Since they are the manufacturer of this device I´m almost certain that they have tested this set before they claim that it works for other machines too. Thank you, if its not impossible, than i think you're right. I have ordered there before and that was a good experience Quote
Members Michiel Posted September 12, 2024 Author Members Report Posted September 12, 2024 4 hours ago, kgg said: Unless you are going to turn the machine into a dedicated edge binding machine it seems to me like a lot of extra work just to do edge binding and then have to strip it down to do regular sewing. I think you have a good point there. For lighter work i have dedicated binder machines to avoid that I'm going to take that into consideration Quote
kgg Posted September 13, 2024 Report Posted September 13, 2024 8 hours ago, Michiel said: I'm going to take that into consideration Here is what I done with my 441 clone to do edge binding using the inexpensive inline binders that I use on all my other machines. This may give you some ideas. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Michiel Posted September 16, 2024 Author Members Report Posted September 16, 2024 Thanks, i think i will give that a try first Quote
Members Patrick1 Posted September 16, 2024 Members Report Posted September 16, 2024 Adler 205 needle plates and feed dogs are not compatible with the Juki 441. The plates are smaller for the Adler and the feed dog is different. As far as I know there is no lateral adjustment for the feed dog to center the needle like the 441. If your interested in a narrow feed dog and plate for your Adler look no further....https://heprecision.com/ Quote
Members canvassewing Posted September 16, 2024 Members Report Posted September 16, 2024 On 9/11/2024 at 8:06 PM, Michiel said: I recently bought an adler 205-370 and would like to buy a moving binder set. Kwok Hing offers one for the juki 441 but they claim it also fits the adler 205. https://www.khsew.com/index.php?route=product/product&product_id=1902 Is that possible? are feed dogs and needle plate for the juki 441 and adler 205 Exchangable? Thanks in advance Michiel Isn't this what you are looking for? - https://www.kwokhing.com/adler/da_205attachment.htm - https://www.khsew.com/index.php?route=product/product&product_id=741&search=khf205 Quote
Members Michiel Posted September 16, 2024 Author Members Report Posted September 16, 2024 Yes you are right! i first was not sure if this was a moving binder, but after looking to the video of Uwe i understood this is also a moving binder (but connected in an other way than the binderset i first looked at. All in all, I do need quite a few parts for this solution (the other option was a complete set) and I don't think I'm doing enough binding to justify the effort of conversion and total cost . i think i will start trying with a non moving binder (for most binding my adler 69 and 67 with moving binder setup will do anyway) Quote
