Members medion Posted September 28, 2024 Members Report Posted September 28, 2024 (edited) Hi all, I am looking at this Pfaff 145 for my father in law - I cannot for the life of me work out why the hook is not doing full rotations. I'm not familiar with this machine, and I was hoping someone could take a look at the following two videos and possibly provide some insight? I understand the throat plate needs to be in place for it all to function, however I've taken a video with and without to try and illustrate the issue: https://www.dropbox.com/scl/fi/b5cdijblzmo7e3nyp4diu/IMG_3732.MOV?rlkey=ewo531ra41pzn97x6ypz0w283&dl=0 https://www.dropbox.com/scl/fi/49sz9e76468dgcoe75aga/IMG_3734.MOV?rlkey=6mz092r091xtutxzlwq87som2&dl=0 Edited September 28, 2024 by medion Quote
Members Constabulary Posted September 28, 2024 Members Report Posted September 28, 2024 I would guess some set screws on the hook driving gears are loose. I´d tilt back the machine and check what is doing on the in drive train when turning the hand wheel. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members fibersport Posted September 28, 2024 Members Report Posted September 28, 2024 Could the safety clutch do that if there is a bunch of thread wound up around the bobbin holder? My guess a good cleaning and adjustment is all it needs. Quote
kgg Posted September 28, 2024 Report Posted September 28, 2024 5 hours ago, medion said: I understand the throat plate needs to be in place for it all to function, however I've taken a video with and without to try and illustrate the issue: 4 hours ago, Constabulary said: I would guess some set screws on the hook driving gears are loose. 1 hour ago, fibersport said: Could the safety clutch do that if there is a bunch of thread wound up around the bobbin holder? If your machine is a Model C or D machine it has a safety clutch. Try resetting the safety clutch. Another problem could be the screws came loose and it put the bobbin gear messing off or a broken tooth. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members medion Posted September 29, 2024 Author Members Report Posted September 29, 2024 Thanks everyone - it was the safety clutch being activated because the hook could not rotate due to being jammed deep underneath with thread and having no oil after sitting for a long time. I was able to pry it apart, clean, oil and then it all started working again and I was able to continue on doing some pre-war vehicle upholstery repairs. Thank you! Quote
Members fibersport Posted October 1, 2024 Members Report Posted October 1, 2024 Glad it was simple! I had a 145 but was able to find a 545 very close to home in better shape. Finding a newer 1245 would be my ultimate machine. Overall they are built like tanks, once you set them up they go for ever. Quote
