11 hours ago, Dwight said:
I have relatively high cheek bones . . . when I want a cheek weld . . . I want it hooked on that riser.
My M14 . . . with my 50 mm scope . . . and my cheek riser.
Decoration is the logo for Destroyer Squadron 7 out of San Diego . . . I rode two ships in that group.
I have sold a number of these . . . mostly one guy sees it . . . wants one.  I make em in basically any height . . . this one is one of my higher ones.
May God bless,
Dwight
Does yours shift under recoil? Made a crude one for my bolt action and laced it down tight, but it still shifted under recoil. Trying to figure out if I need to just anchor the laces around the sling stud or if I need to change my construction method.
  • Replies 23
  • Created
  • Last Reply
Top Posters In This Topic
I know on the cheek pad on a M1D Garand (the sniper variant) they put a brass wood screw into the bottom of the leather to keep it from shifting.  A rifle stock is just an oddly shaped taper than makes it tough to secure a piece of leather to it.  You could place a thin piece of rubber between the wood and leather.  I keep an old bicycle innertube in the workbench that I occasionally cut pieces off of for various similar type applications.  - also comes in handy to make spacers, vibration dampening, or for a non-skip type application.
Regards,
Littlef
Littlef - YouTube
  • CFM
Here is mine i used the technique on the original M1 scope risers, a slot is cut into the leather plus the string is wrapped, mine doesn't add rise because it is open-sighted but adds padding for a good weld. I  had one stock-mounted bullet loop thing and lost to many shells with it so I tossed it out, they don't work well for rimless cartridges if your hunting requires more than sitting in a blind or tree stand.
  • CFM
actually, i misspoke i lengthened it so i didn't have to use a screw in my stock. Sorry I'm getting old lol.
On 11/1/2024 at 9:31 PM, 1961Mike said:
The saddle bags would have two flaps that could be decorated as well as the connection between the two bags.
That's an idea.  I like projects with a lot of "canvas" to work from.
18 hours ago, DoogMeister said:
With cartridge loops, decorative carving would be on the inside - the shooter can see it and appreciate it that way.
Fair,  I just worry about skin oil, sweat, etc. prematurely aging the work.
In a one word answer . . . no . . .
It doesn't.  But then again . . . this is laced on there TIGHT . . .  TIGHT
Plus . . . if it moved it would have to move forward . . . and mine is designed to end at that skinny part of the stock . . . so it would have to jump over the hand grip . . .  ain't gonna happen.
May God bless,
Dwight
www.dwightsgunleather.com
May God bless,
Dwight
Thanks.  I may need to adjust my design and then make sure I can really crank the lacing down.  Just gotta be careful that I don't damage the stock (lightweight polymer bolt gun I bought for humping all over the hills).
Here in Colorado, we have to have our guns in a case or scabbard while on an ATV/UTV.  I use the cartridge loops so I don't have to dig around in a pocket for them when I stop and remove the gun from the scabbard.  Otherwise, I agree - cartridge loops are a quick way to lose (expensive) ammo.
  • CFM
You can have ammo in the magazine can't you?
I'm not too fond of that pocket problem as well, here is my fix for that.
Yeah . . . I don't like pocket ammo either . . .
My fix is a bit different . . . quicker too . . . lol
May God bless,
Dwight
Edited by Dwight
