Members LRBespokeGoods Posted October 31, 2024 Members Report Posted October 31, 2024 So... I'm hoping this isn't too much of a daft question after the lengthy back story... But... I've had a friend of mine ask me to push my still fairly limited skillset and build them a holster and drop gun belt for a replica Colt .45 SAA single action pistol (his description based on the replica he has provided me to work with, looks like a cowboy gun to me as i'm not a pistol person). I have followed a couple of very detailed descriptions on how to template and assemble the holster and have been somewhat successful... however, with both methods used after some gentle wet forming around the replica firearms the pistol is rather firm to both insert and remove from the holster unlike what I see in movie magic or the youtube gunslingers. I can hold the holster upside down and shake it quite vigorously without the pistol coming out. I will be remodelling the template anyway as it looks a little wobbly in places and I am planning on lining the holster for the final build so will require a touch more space. My question is this, how tight is too tight for a holster? Quote
Members bland Posted October 31, 2024 Members Report Posted October 31, 2024 If it is a western style, you do not want to wet mold it very tight. Al Stohlman, Will Gohrmley , and many others have patterns out there. There are several YouTube videos on the subject. There are several threads on this forum to assist you. Search the posts on the forum. Most will have a hammer thong to hold the revolver in the holster in place. Quote
Members LRBespokeGoods Posted October 31, 2024 Author Members Report Posted October 31, 2024 Many thanks Bland, not nearly that tight is the answer For one mock up I did follow a very in depth methodology from somewhere on this site (unfortunately I cant remember who to give credit) but it came out fairly tight just as the non LWN method did... so wanted to check if that was the norm, which I now understand is not the case... Maybe i'm doing something fundamentally wrong! Quote
Members BlackDragon Posted October 31, 2024 Members Report Posted October 31, 2024 Thightness depends on function. If your friend wants a quick draw holster then you dont want it tight at all. If its standard carrying holster you want it a little snug but you dont want it to lock in. Normally with western holsters you dont have to wet mold, although people do. When you make the holster you make a retention strap to hold the pistol in place Quote
Members LRBespokeGoods Posted October 31, 2024 Author Members Report Posted October 31, 2024 Thanks BlackDragon for the expansion. Just to double check my understanding then, majority of the retention is provided by the hammer thong or strap? and I have to get on to my friend for his exact thoughts on usage. Quote
Members Mablung Posted October 31, 2024 Members Report Posted October 31, 2024 9 minutes ago, LRBespokeGoods said: Thanks BlackDragon for the expansion. Just to double check my understanding then, majority of the retention is provided by the hammer thong or strap? and I have to get on to my friend for his exact thoughts on usage. If he wants the holster to be something of a replica of a holster in use at the time the original pistols were used, you’re correct. Holsters like that are not “boned” (wet-molded to the creases and contours of the pistol), unlike most holsters made now. Quote
Members LRBespokeGoods Posted October 31, 2024 Author Members Report Posted October 31, 2024 Thank you all for your help! Quote
CFM chuck123wapati Posted October 31, 2024 CFM Report Posted October 31, 2024 put it on a belt and try it. It should come out smoothly with no hangup. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
CFM chuck123wapati Posted October 31, 2024 CFM Report Posted October 31, 2024 you wet mold this type around the cylinder and trigger guard only, the gun should slip in easily/ fall into place but still fit snugly so the blueing isn't worn off by jostling around. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members dikman Posted October 31, 2024 Members Report Posted October 31, 2024 What do you mean by "drop gun belt"? Buscadero style? If you want it to be historically accurate then the only wet molding is to fold the leather around the revolver in order to line up the edges for stitching. I wrap the revolver in a couple of layers of cloth (to give it a bit of bulk) and then in clingwrap to keep the revolver dry, wet the stitched holster and force the revolver in then as the leather dries keep wriggling/twisting it. This should ensure there is minimal retention. There's probably other ways but this has worked for me. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members LRBespokeGoods Posted October 31, 2024 Author Members Report Posted October 31, 2024 Thank you Dikman, I wasn't aware that was the correct name for the belt but is what we were thinking of. I can't wait to get something built to try out everyone's suggestions! Quote
AlZilla Posted November 1, 2024 Report Posted November 1, 2024 You're getting to make the whole rig, and I'm jealous. I love all that western gear and have no need of it. I did make a couple of holsters that sit 4 or so inches below the belt. I like it a hell of a lot better than a regular belt holster. Just ask the end user what he wants for retention. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Members Handstitched Posted November 8, 2024 Members Report Posted November 8, 2024 Al Stohlmans holsters pattern book is a great book to have ,I enjoyed making some of them , even just for the experience and for show, but no too many people are interested in the 'western style holsters' these days, and not to go too off topic, but gun laws are very tight here, and here in the west of Oz, they just got tighter. HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
