Members stennes Posted January 13 Members Report Posted January 13 Any ideas would help, relative passed and I have know idea about this beast? Quote
ljk Posted January 14 Report Posted January 14 That is a USMC model c or a version. The manual is available online. Was commonly used for cutting soles. Not allowed in factories for years because of inadvertent double clicking when flywheel and clutch get hot. Great hobby machine. Perfect machine for me because I make my own dies out of steel rule. Usually runs on 220 single phase one HP motor. The machine will jam if depth is set wrong, you need big monkey wrench to back off flywheel. As a parts machine $500 or less. In good working order $1000-$1500 Quote
Members stennes Posted January 15 Author Members Report Posted January 15 3 hours ago, ljk said: That is a USMC model c or a version. The manual is available online. Was commonly used for cutting soles. Not allowed in factories for years because of inadvertent double clicking when flywheel and clutch get hot. Great hobby machine. Perfect machine for me because I make my own dies out of steel rule. Usually runs on 220 single phase one HP motor. The machine will jam if depth is set wrong, you need big monkey wrench to back off flywheel. As a parts machine $500 or less. In good working order $1000-$1500 Thank you very much for input, that is great info. Quote
Members Cumberland Highpower Posted January 15 Members Report Posted January 15 (edited) LIK is probably right on value, at least here in the States. In Canada, it could be worth more? I've seen them sell in working condition anywhere from $200 to 2k. Amish are willing to pay top dollar, everyone else, not really. They're also not OSHA approved because they don't have a lockout or 2 hand safety switch like a modern clicker. There is an outfit that refits them to air, but they are slow and the conversion is too expensive if you're not Amish. lIK is also right about the double clicking issue and getting stuck. If you use one allot you'll become accustomed to it and learn to work around it. Might be what you need. I would not recommend one if you do much clicking though. I once bought a Reece Model A for $30 at an auction and on the way home I decided I didn't want it in my shop...Swung by the local scrap yard and offloaded it for $70! Edited January 15 by Cumberland Highpower Quote
Members stennes Posted January 15 Author Members Report Posted January 15 Thank you for that, now that I know more I’m going to post it on the Facebook site and see if I can get it sold. Quote
Northmount Posted January 15 Report Posted January 15 1 hour ago, stennes said: Thank you for that, now that I know more I’m going to post it on the Facebook site and see if I can get it sold. You can post it here in the Marketplace > Items For Sale > Miscellaneous/Other Check the Marketplace rules here: https://leatherworker.net/forum/forum/70-announcements/ Quote
Members mbnaegle Posted May 1 Members Report Posted May 1 I agree with Cumberland above. Any working machine is better than nothing, but from a support and safety perspective, those old Model C's have major drawbacks. All clickers, regardless of if they work or have parts available to buy, are a bear to move. Their weight and tendency to tip over and cause damage when not properly moved, mean that they're not really a machine that's cheap/easy to swap out if it doesn't work for your needs, so it's something to consider when you make a purchase. Quote
ljk Posted May 2 Report Posted May 2 I think we have been a little harsh about this machine. If you cutting key fobs, vest extender ends, ear rings etc. this is the machine for you. If I'm making a pair of boots that's about 15 cuts in a couple minutes for soles and heels. If adjusted properly, about 500 cuts before double clicking. If you are considering this machine use a 2" 20X40 board red or white. Quote
