Members PaulMer Posted January 29, 2025 Members Report Posted January 29, 2025 Hook to needle clearance is too great, little less than 1/16". Experiencing skipping, of course. Can not find anything from Adler books or videos on how to adjust clearance. Much different set-up than a Class7 Hook adjustment. Quote
Northmount Posted January 29, 2025 Report Posted January 29, 2025 1 hour ago, PaulMer said: Hook to needle clearance is too great, little less than 1/16". Experiencing skipping, of course. Can not find anything from Adler books or videos on how to adjust clearance. Much different set-up than a Class7 Hook adjustment. Moved your post to leather sewing machines, you'll get more response here, this is where the machine guys hang out. Quote
Members PaulMer Posted January 29, 2025 Author Members Report Posted January 29, 2025 Thank you and that's funny. Quote
Members Constabulary Posted January 29, 2025 Members Report Posted January 29, 2025 (edited) not sure what you mean with needle hook clearance? You mean the distance from the needle to the hook tip? If you mean the rise from the BDC to form a loop then 1/16" is not enough. Machines with 328, 214 or 216 needles usually have a rise of 3.5mm - 4mm from BDC. Edited January 29, 2025 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members PaulMer Posted January 29, 2025 Author Members Report Posted January 29, 2025 The clearance from hook tip to Needle scarf for the hook to to catch the loop. Most clearances should be about 0.1mm and this machine is way greater than that. Quote
Members Michiel Posted January 29, 2025 Members Report Posted January 29, 2025 If I remember correctly, the distance is set with shims Quote
Members PaulMer Posted January 29, 2025 Author Members Report Posted January 29, 2025 2 minutes ago, Michiel said: If I remember correctly, the distance is set with shims Thank you and I kinda heard that around town as well. Wanted confirmation. That will get the hook in place, but, in addition, the hook driver is need of adjustment as well. There is no needle support/guard and the needle is just floating out there. Quote
Members Michiel Posted January 29, 2025 Members Report Posted January 29, 2025 Hook setup is the same as adler 205-102 adler 266 and adler 366 (Part 266 15 on this one) I think the hookdriver act as an needle guard Quote
Members Michiel Posted January 29, 2025 Members Report Posted January 29, 2025 I think i had some help from the service manual for the adler 366 when I worked on my adler 166 Quote
Members Michiel Posted January 29, 2025 Members Report Posted January 29, 2025 I might be wrong but i think i have had a 166 where one can turn the race for the barrelhook to move it front and backwards you could try that…. Quote
