Members Woehlk Posted February 8 Members Report Posted February 8 Help me!, im lost!. spendt 5 hours yesterday at this, and have not gotten any wiser!. Something is totally wrong with my tension. I can make it perfect, and then, it skips a few. I use Schmetz 134 LR size 21, and Serafil 20 Tex 135 Quote
Members Woehlk Posted February 16 Author Members Report Posted February 16 No one have an idea how to fix this? Quote
Members shoepatcher Posted February 16 Members Report Posted February 16 thread size and needle you are using? More pics of the the tension area please. Also the model plate in front. Pics lease. glenn Quote
Members Woehlk Posted March 5 Author Members Report Posted March 5 (edited) Hey Shoepatcher!, thanks for your answer!, here is the front and backsides. When the knot gets at the bottom, and even though I just change the upper tension the slightests, the knots get on top. Even trying one several meters of leather, I cannot find the sweet spot. The leather is 3.5mm thickness. Needle is SCMETZ NM; 130 SIZE: 21 134 LR Thread is is Serafil 20 Tex 125 Bobbin tension: I do the drop test. where I drop the bobbin like a yoyo, and the thread gives a little. Edited March 5 by Woehlk Quote
kgg Posted March 5 Report Posted March 5 On 3/5/2025 at 4:10 PM, Woehlk said: The leather is 3.5mm thickness. Needle is SCMETZ NM; 130 SIZE: 21 134 LR Thread is is Serafil 20 Tex 125 Expand The needle size is incorrect for Tex 125 (V138). Reference needle size to thread size ( https://www.tolindsewmach.com/thread-chart.html ). That size of thread you should use a 140 (#22) or 160 (#23) and in thick or tough leather 180 (#24). That said the PFAFF 335 is regarded as a binding machine with the older casing machines rated for a 120 (#19) for a Tex 90 (V92) thread. Reference manual ( http://docs.uwe.net/Pfaff-335-Instruction-Book-Old-Casting.pdf ). The newer body machines are rated to a 100 needle. When you go above the rated max's of the machine you could or probably will have problems with needle to hook clearances, etc. which then can result in other stitching / tension problems. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Woehlk Posted March 5 Author Members Report Posted March 5 Thank you so much Kgg!, I had researched the needle to thread before, Just talked to some fellow danish leatherworkers, that said it was okay. they said the thread just needed to be inside the channel of the needle. But you have real references, so that is something I can actually use!. Would you recommend me buying new thread? or new needles. or both. And if yes, what sizes Quote
kgg Posted March 5 Report Posted March 5 On 3/5/2025 at 5:49 PM, Woehlk said: Would you recommend me buying new thread? or new needles. or both. Expand If you want to use V138 buy a machine like / similar to the class 341/1341 like a Juki LS-1341 or an older Juki LS-341 or their clones. Otherwise reduce the thread size to a max of V92 with the correct needles in your projects. Personally I think this is the wrong class / type of machine for your needs in 3.5 mm leather. If most of your projects are leather be done with it and get a new / used Class 341/1341 machine. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members shoepatcher Posted March 5 Members Report Posted March 5 You can sew #138 on a Pfaff 335 but you must enlarge the hole in the feed dog and inner foot to accommodate the #138 thread. I also just touch the the corners of the space bar on the the machine. That is where the gap on the bobbin case is that the thread passes by the each stitch. 335 Pfaff do not have a bobbin case opener since they are a horizontal hook machine. glenn Quote
Members dikman Posted March 5 Members Report Posted March 5 I have an old casting 335 and after much tinkering and adjusting I got it to sew #138 - but it wasn't happy about it. It was much better with #69. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members shoepatcher Posted March 5 Members Report Posted March 5 On 3/5/2025 at 9:48 PM, shoepatcher said: You can sew #138 on a Pfaff 335 but you must enlarge the hole in the feed dog and inner foot to accommodate the #138 thread. I also just touch the the corners of the space bar on the the machine. That is where the gap on the bobbin case is that the thread passes by the each stitch. 335 Pfaff do not have a bobbin case opener since they are a horizontal hook machine. glenn Expand Quote
Members Woehlk Posted March 5 Author Members Report Posted March 5 On 3/5/2025 at 6:08 PM, kgg said: If you want to use V138 buy a machine like / similar to the class 341/1341 like a Juki LS-1341 or an older Juki LS-341 or their clones. Otherwise reduce the thread size to a max of V92 with the correct needles in your projects. Personally I think this is the wrong class / type of machine for your needs in 3.5 mm leather. If most of your projects are leather be done with it and get a new / used Class 341/1341 machine. kgg Expand When I bought the needles and thread, is used this chart as reference. From Serafil, that is why I thought it should work Quote
Members Woehlk Posted March 5 Author Members Report Posted March 5 On 3/5/2025 at 9:48 PM, shoepatcher said: You can sew #138 on a Pfaff 335 but you must enlarge the hole in the feed dog and inner foot to accommodate the #138 thread. I also just touch the the corners of the space bar on the the machine. That is where the gap on the bobbin case is that the thread passes by the each stitch. 335 Pfaff do not have a bobbin case opener since they are a horizontal hook machine. glenn Expand That makes sense!. I can see they thread really is a limit when in the bobin case, but I was to afraid to file it down, since its hard to get a new one. Quote
Members Woehlk Posted March 5 Author Members Report Posted March 5 (edited) On 3/5/2025 at 10:00 PM, dikman said: I have an old casting 335 and after much tinkering and adjusting I got it to sew #138 - but it wasn't happy about it. It was much better with #69. Expand That is such a thin thread. I handsew like 100% of my work. but my wish is to do belt and dog leashes on the machine instead. I think Tex90 is the smallest the still looks good Edited March 5 by Northmount fixed a couple typos Quote
kgg Posted March 6 Report Posted March 6 On 3/5/2025 at 10:18 PM, Woehlk said: When I bought the needles and thread, is used this chart as reference. Expand I think they are basing the sizing for most types of fabric verses sewing leather. Remember when sewing leather the hole the needle creates has to be large enough so the fibers of the leather don't catch the thread as the needle cuts through. Example the Juki LS-1341 is rated for V138 with a 180 (#24) needle for sewing thick and tough material rather then rating the machine for Tex 210 (V207) based on the capacity of the needle. Just because you can stuff the thread through the eye of the needle doesn't mean it will stitch consistently or correctly. Some factors that need to be considered, thickness of the item being sewn, material type (cotton vs ripstop vs Kevlar vs leather(chrome tan vs veg tan)) and the shape of needle tip round to separate fibers or cutting to slice through to name a few. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members dikman Posted March 6 Members Report Posted March 6 On 3/5/2025 at 10:31 PM, Woehlk said: That is such a thin thread. I handsew like 100% of my work. but my wish is to do belt and dog leashes on the machine instead. I think Tex90 is the smallest the still looks good Expand That's always an issue when you're used to the thickness of hand stitching. To try and replicate the look (thickness) you're getting into harness stitching machine territory. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members shoepatcher Posted March 9 Members Report Posted March 9 On 3/5/2025 at 10:21 PM, Woehlk said: That makes sense!. I can see they thread really is a limit when in the bobin case, but I was to afraid to file it down, since its hard to get a new one. Expand Dremel the corners very light with a sanding disc. Dremel the corners very lightly with a sanding drum.; glenn Quote
