Members brae Posted February 17, 2025 Members Report Posted February 17, 2025 Does anyone know if a 2/5 high power Consew clutch motor needs to be greased or oiled? Just by estimate, this motor could be 30-40 yrs. old. I don't ever remember seeing or hearing anyone mention oiling or grease for the motor. Recently the machine sounds different & is not sewing correctly. I'd appreciate any help as I sure don't want to ruin the motor. Thank you Quote
Members sinneD Posted February 17, 2025 Members Report Posted February 17, 2025 Do you mean the motor or the clutch mechanism? There a bunch of threads here on oiling motors that helped me out. Try searching for it. Do you have oil ports on the motor? Here is a vidoe and pic of one. Oil Port on clutch motor housing This video helped me out too. https://www.youtube.com/watch?v=oQ0W90XfP6Y Quote
Members Constabulary Posted February 17, 2025 Members Report Posted February 17, 2025 the reason likely is that clutch motors are way outdated nowadays. On my side of the pond you sometimes find 750w Servo motors for about 70€ (not kidding) but that of course is super cheap. Anyway you find proper servo motors for 120 - 150 € or $ so for me I see no reason not to replace a clutch motor that needs service or maybe bearings with a energy saving servo motor. But that's just me. If you want to invest work time and maybe money into an old clutch motor go a head. I would not do that. Just my 2 cents. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
CowboyBob Posted February 17, 2025 Report Posted February 17, 2025 16 hours ago, brae said: Does anyone know if a 2/5 high power Consew clutch motor needs to be greased or oiled? Just by estimate, this motor could be 30-40 yrs. old. I don't ever remember seeing or hearing anyone mention oiling or grease for the motor. Recently the machine sounds different & is not sewing correctly. I'd appreciate any help as I sure don't want to ruin the motor. Thank you This motor has sealed bearings,there (might) be an oil hole in the center of the casting to the left of the pulley to lube the bearing for the clutch. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members Cumberland Highpower Posted February 17, 2025 Members Report Posted February 17, 2025 I think they're mostly sealed bearing units? There is a sleeve that moves in the housing that could use a little oil, it slides back and forth when you engage it. try lubing that. CM's are tough and can last just about forever. I have one on a Randall that was made in 1984 and I use it every day nearly. I've adjusted the Cluch/Brake a couple times since I've owned it over the last 20 years. You can buy the friction plates and bearings for some of the better ones, but buying a used CM is often cheaper. They're not obsolete at all and are still made. There are just better and worse uses for them these days. Servos are great when you want a positioner and on leather stitchers for beginners (and non beginners) I find CM's on heavy sewing machines that are run full throttle for long durations is best. I highly doubt you'll get any Chinese Servo to last 40 years though, more like 5 if you use it allot. Maybe an Efka or Mitsubishi can make it to 50yrs? I can tell you one thing that's a negative about Servos, you can't tell from the sound if they're on. I recently put a needle through the tip of my finger when inserting a bobbin on a Seiko. Lucky for myself the needle didn't shatter....If it had been a CM I'd have known it was on. Quote
Members Wyowally Posted February 17, 2025 Members Report Posted February 17, 2025 Probably no help, but here goes: My first tabled, clutch motor machine was a Necchi BV. These had the head imported, then installed with a US made induction motor in a table. The old induction clutch motor had lubrication holes - but the motor was installed with the holes on the bottom! The old bushings were shot, I machined and installed oilite bushings. Not silent, but pretty quiet, and I can manipulate the clutch for slow sewing. Quote
Members Cumberland Highpower Posted February 18, 2025 Members Report Posted February 18, 2025 (edited) 20 hours ago, Wyowally said: Probably no help, but here goes: My first tabled, clutch motor machine was a Necchi BV. These had the head imported, then installed with a US made induction motor in a table. The old induction clutch motor had lubrication holes - but the motor was installed with the holes on the bottom! The old bushings were shot, I machined and installed oilite bushings. Not silent, but pretty quiet, and I can manipulate the clutch for slow sewing. When I was a boy my mother went through allot of home sewing machines. One day my dad bought a Necchi BU in a cabinet from a hoarder for $20. She still has the Necchi and I think it was the best home use machine ever made. Edited February 18, 2025 by Cumberland Highpower Quote
