Members RipVanWinkle Posted March 1, 2025 Members Report Posted March 1, 2025 (edited) Hi all, I’ve been prototyping and experimenting with some things for a hat and I’ve gotten to the part I’ve dreaded, tweaking a pre-existing hat pattern, and I’m faced with the issue of the fit and the measurements, I want the top and bottom measurements to be the same but I just need it a bit taller, I’m not a smart man so my approach was to just cut it and see if I could Macgyver a solution, I don’t this that was the approach I should’ve done, anyone have any advice or pointers? any and all is appreciated! pic related, pls excuse the mess that is my workbench Edited March 1, 2025 by RipVanWinkle Quote
AlZilla Posted March 1, 2025 Report Posted March 1, 2025 Well, that's similar to the way I've seen sewing patterns altered. Did you try just making a straight across cut? It looks like the top half is now wider than the bottom but that just makes no sense ... Definitely following this one. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Members RipVanWinkle Posted March 1, 2025 Author Members Report Posted March 1, 2025 41 minutes ago, AlZilla said: Well, that's similar to the way I've seen sewing patterns altered. Did you try just making a straight across cut? It looks like the top half is now wider than the bottom but that just makes no sense ... Definitely following this one. Your response is pretty comforting, not gonna lie, I’m pretty stumped on what to do, I’m not sure if making it a straight cut would change but i may try it, I’m a caveman when it comes to figuring out computers so i wanna try to do this by hand if i can. Quote
Members Beehive Posted March 1, 2025 Members Report Posted March 1, 2025 8 minutes ago, RipVanWinkle said: Your response is pretty comforting, not gonna lie, I’m pretty stumped on what to do, I’m not sure if making it a straight cut would change but i may try it, I’m a caveman when it comes to figuring out computers so i wanna try to do this by hand if i can. You're in good company. Quote
Members DieselTech Posted March 1, 2025 Members Report Posted March 1, 2025 Why can't you add the heighth on the top of the hat pattern like you want. Then just modify the top part of the pattern/cap. It will be a bit smaller at the top, but keep the headband size unchanged. Quote
Members DieselTech Posted March 1, 2025 Members Report Posted March 1, 2025 This is my ugly art work off my phone. But add the height you want to the top of the pattern. Hopefully you can see/understand what I mean. Quote
AlZilla Posted March 2, 2025 Report Posted March 2, 2025 53 minutes ago, DieselTech said: This is my ugly art work off my phone. But add the height you want to the top of the pattern. Hopefully you can see/understand what I mean. That may be as easy as anything. The top piece would then have to be shrunk a little and the stitching holes re-aligned. I've worked with a couple of hat patterns like this one and the hole count is critical. I've used 1/8" craft foam sheets to mock up patterns. This looks like a perfect use case. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Members BlackDragon Posted March 2, 2025 Members Report Posted March 2, 2025 You're on the right path so far. You need to keep the top and bottom lines the same length. If you dont the brim and top would have to be resized. Your side angles have to change a little. All you have to is draw a line from your new top corner to your bottom corner on both sides. To be sure it works just mock it up and make sure your lines meet up. Quote
Members RipVanWinkle Posted March 2, 2025 Author Members Report Posted March 2, 2025 3 hours ago, BlackDragon said: You're on the right path so far. You need to keep the top and bottom lines the same length. If you dont the brim and top would have to be resized. Your side angles have to change a little. All you have to is draw a line from your new top corner to your bottom corner on both sides. To be sure it works just mock it up and make sure your lines meet up. I think that might do it! I did just that and it all still lines up! thanks! Quote
Members Handstitched Posted March 5, 2025 Members Report Posted March 5, 2025 I have modified a hat pattern by ' diesel punk' before to make it a bit taller into a ' top hat' . It did take a lot of thinking, and counting a lot of holes to make sure everything lined up, but it did work out. I didn't bother with the ' slash' style hat as thats been done to death, so I made a nice carved hat band. Came out good. HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
