Members Winks Posted 6 hours ago Members Report Posted 6 hours ago When the wheel is turned the timing gear turns without moving the gears. If I turn the handwheel toward the back, it catches the knob and turns the gears fine. Is there a way to reverse that lever or knob so it catches the right way? Let me know if there's a way to insert a picture if it would help. Quote
Northmount Posted 5 hours ago Report Posted 5 hours ago 1 hour ago, Winks said: When the wheel is turned the timing gear turns without moving the gears. If I turn the handwheel toward the back, it catches the knob and turns the gears fine. Is there a way to reverse that lever or knob so it catches the right way? Let me know if there's a way to insert a picture if it would help. A picture or a movie would help. You can put the movie on YouTube and link to it here. Quote
