Members Valenj01 Posted March 8 Members Report Posted March 8 Hey all. I picked up a Cobra Class 4 not too long ago. I love this machine. It makes sewing thick veg great. I routinely make saddle bags and pouches so this was a great edition. I had a thought to try to sew some of the thicker oil and chrome tan pouch projects I have, 3-5 layers over a 1/4 inch thick total, but the stitch on the top side of the project is way to deep but otherwise fine. Its like a ditch. The bottom stitch is perfect. Knots are good and centered. I did have to modify the foot pressure a bit but I expected that. I get that the leather is softer but this is not what I expected would happen, really. I've tried playing with the tension but that resulted in messing up the knots and stitch. Is there some way to adjust to make this work on this machine? Quote
Northmount Posted March 8 Report Posted March 8 On 3/8/2025 at 12:31 AM, Valenj01 said: I picked up a Cobra Class 4 Expand Moved your post to leather sewing machines. Quote
Moderator Wizcrafts Posted March 8 Moderator Report Posted March 8 On 3/8/2025 at 12:31 AM, Valenj01 said: I have, 3-5 layers over a 1/4 inch thick total, but the stitch on the top side of the project is way to deep but otherwise fine. Its like a ditch. Expand You are probably using the Schmetz S point needles that came with the machine. It's their nature to create a submerged appearance on top because of their geometry. Order you some diamond point needles and the stitches will lay more on top and appear longer. Some are 3 sided and some are 4 sided. Their holes are closer in appearance to round points than the S points are. You might even be able to use round point needles with chrome tan leather. I use them all the time when I sew embroidered patches onto leathers. But, they're done on smaller walking foot and patcher machines. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Valenj01 Posted March 8 Author Members Report Posted March 8 Thanks, I will try the needles. Is there a specific foot you recommend or anything? Quote
Members DieselTech Posted March 8 Members Report Posted March 8 Idk if a narrow feed dog & plate could help eliminate some of your stitching issues. As mentioned the diamond point or LR point needles, don't seem to pull the stitches down as deep as a S point needle. Quote
