I bought a used Consew255 rb a while ago and after trying to set it up there was several issues. It had been painted and was filthy inside , I ordered a new feed dog, plate , needle bar and thread tensioner.
I finally got around to cleaning and oiling everything to make sure everything was moving freely.
When raising the presser foot it do not release the tensioner. I got the release pin freed up and was able to get it out of the hole.  It doesn't move when the presser foot lever is raised to engage the paddle on the new tensioner, I could really use some guidance on this if anyone has the time.
I took a picture of the serial number as there is no tag designating model One or Two. I also include a picture of the release pin.
Thanks, Terry
Edited by Southerngunner
Here is a Pic of the machine
6 minutes ago, Northmount said:
Stretch the pin!  LOL
Find a nail or rod the same diameter and cut it longer than the current pin.  Test it, if too long or not long enough, shorten it or make a new one longer.
That's a great idea, It's raining like cats and dog's here so when I can get down  to my shop I will try it  and update, Thanks
I would but I broke my pin stretcher last week gosh dang it.
If you push on the pin lightly with the foot down & lift it & the pin doesn't move the tension release bracket is broken.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
I tried that several times and it doesnt move at all when engaging the  lift. Where might be the best place to order one , and are they  different between the  1 or 2 models since I'm not sure if mine is a 255-1 or 2
more info
Give me a call,we stock them,both 1 & 2 take the same part.They are a real buggar to install.
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Thanks Bob , It looks like it will be a pain in the butt to install but I'll holler at you and get one coming this way Thanks for your help
Terry
