Members mous3 Posted April 10, 2025 Members Report Posted April 10, 2025 (edited) Hi I have my eyes on the following: SINGER 45K/89 HEAVY DUTY CYLINDER ARM INDUSTRIAL SEWING MACHINE. Singer 47W66 Cylinder Arm Walking Foot WIMSEW W-8B Cylinder Arm Walking Foot Needle Feed Sewing Machine Wimsew 246 cylinder arm machine I predominantly work with biothane up to 15mm thick Max Which one of these options would you go for or something totally different Because hand stitching is not viable for doing more than gifts for family and friends I need to get machine Edited April 10, 2025 by mous3 Quote
Members Tigweldor Posted April 10, 2025 Members Report Posted April 10, 2025 The Singer 45K usually does not have reverse and is only good to about 1/2 inch material thickness - 15mm would be stretching it´s limit. It is also not a walking foot machine - real slippery material is not what that machine is made for - not saying it can´t be done though. The Wimsew is a compound sewing machine - as you have mentioned - it also has reverse and comes with a modern motor - get the 1000Watt motor. Spare parts and different feet are available for small coin. I would call it a cheap clone of the Adler 205 - not as well made though. But as always : you only get what you pay for. Can you get a Wimsew 8B for 800quid ? That would be my choice for day in and day out use in a business - even though I like older machines. Just my opinion Hans Quote
Contributing Member fredk Posted April 10, 2025 Contributing Member Report Posted April 10, 2025 @mous3 you should get together with @machineage He's got a Wimsew W-0618-1 Walking Foot Sewing Machine for sale in Staffordshire and its within your budget Quote Al speling misteaks aer all mi own werk..
Northmount Posted April 10, 2025 Report Posted April 10, 2025 6 hours ago, mous3 said: I need to get machine Moved to Leather sewing machines Quote
Members mous3 Posted April 10, 2025 Author Members Report Posted April 10, 2025 Hans yes I can it appears one is available on eBay locally shocked there is also a Adler on market place in my budget but not advertised the model number Thanks for your help 1 hour ago, fredk said: @mous3 you should get together with @machineage He's got a Wimsew W-0618-1 Walking Foot Sewing Machine for sale in Staffordshire and its within your budget I will do thanks Quote
Members mous3 Posted April 10, 2025 Author Members Report Posted April 10, 2025 I have just found an Adler 205-64 cylinder arm machine also in my budget between that and the Wimsew the Adler is a 8hr road trip away though Quote
kgg Posted April 10, 2025 Report Posted April 10, 2025 1 hour ago, mous3 said: I have just found an Adler 205-64 cylinder arm machine The 205-64 is a bottom+needle feed machine not a compound feed (feed dog + needle + presser foot). kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Tigweldor Posted April 11, 2025 Members Report Posted April 11, 2025 (edited) Lets put it this way plain, if you want to do yourself a favour that you won´t regret : If you want to sew multiple layers of webbing - especially Nylon or some other slippery material - a compound sewing machine is so much more efficient - in my eyes a definite must have. Makes work so much more enjoyable, less frustrating as well - that is worth more than gold. A good cylinder arm with a clamp on table - maybe even a little and a big table - you got 2 machines in one - saves space and cash. Most all cylinder / open arm sewing machines have always come with some type of latch or tapped screw hole for affixing the table on the pulley side of the arm and different kinds of bottom table support on the needle end side - is nobody reinventing the wheel on that idea - most likely been around for as long as open arm sewing machines have been in existence. Hans Edited April 11, 2025 by Tigweldor Quote
kgg Posted April 11, 2025 Report Posted April 11, 2025 13 hours ago, mous3 said: Which one of these options would you go for or something totally different If I'm not mistaken the sewing capacity of the machines you are looking at is roughly 12mm and you want to sew 15mm. The machines so far are what I would consider similar machines to the Juki LS-1341 or Juki LS-341 sewing capabilities with a max thread size on top and in the bobbin of V138 ( .4mm ) in max sewing thickness. You may sew 15mm occasionally depending on the needle thread combination, the type material and the toughness of material but consistently probably not. To sew 15mm which is touch less then 5/8" really you are into a class 441 machine similar to a Juki TSC-441 or clone. 13 hours ago, mous3 said: Because hand stitching is not viable for doing more than gifts for family and friends I need to get machine Since you are hand stitching you are probably using .8mm thread which is roughly V554 / T600 / Tkt 5. That thread size will exceed even the Juki TSC441 or clones which can handle V415 (.7mm). Another option maybe a one arm bandit in the Class 441. In that class you have three options Tippman Boss, Cowboy Outlaw and the Weaver Cub but will still be limited to V415 thread. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members mous3 Posted April 11, 2025 Author Members Report Posted April 11, 2025 (edited) I have just found a wilcox and gibbs s335B also in my price range I very very rarely would be doing more than 12mm thick biothane and I can live with hand stitching those rare sections, I understand that I will be using thinner threads that I formation is most helpful, I can hand stitch with thinner thread and have been experimenting with 0.6 mm it works well I definitely want to go with cylinder arm machine because it will fit into all the small awkward bits of making a dog's harness and like people have said with the little DIY engineering to you can turn into a flatbed machine but you can't turn a flatbed machine into a cylinder arm machine. Edited April 11, 2025 by mous3 Quote
