Members friquant Posted April 12 Author Members Report Posted April 12 @kgg Suggested a smaller needle. Here is a sample with a size 100 needle, front and back. Quote In search of the perfect hundred-dollar servo motor with needle positioner. friquant. Pronounced "FREE-kwuhnt"
kgg Posted April 12 Report Posted April 12 (edited) 1 hour ago, friquant said: Suggested a smaller needle. I don't think you will ever get a good stitch when the material is .4mm thick and the bobbin thread is .292 thick and the top thread is .292 thick for a total thickness at the knot of .584. I think you would have to down to something like V33 thread. I think the stitch line in the paper versus the fabric has to do with the paper being rigid and the fibers fabric move as the needle enters. The lack of fabric friction, the fabric weave, the thinness of the material and the V69 being UNbonded probably is causing the thread to twist/curl. Try a seam with 3 layers and see what happens. kgg Edited April 12 by kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Moderator Wizcrafts Posted April 12 Moderator Report Posted April 12 @friquant Try some #46 bonded thread with a #14 round point needle. This material may not like bonded thread. Try household polycore thread, which is close to number 50, which is close to bonded 46. Reposition the check spring to the center position. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Moderator Wizcrafts Posted April 12 Moderator Report Posted April 12 7 hours ago, AlZilla said: That's just PHD-level sewing knowledge that you aren't gong to find anywhere else. Thanks! One reason for me using Schmetz Serv 7 needles is that the larger eye is a little less likely to get clogged up when I sew through double-sided leather basting tape from Wawak, or contact cement, or other glues. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
MikeRock Posted April 13 Report Posted April 13 Wiz, Do the curlicues have anything to do with the twist of the thread, left vs. right? Quote
Members shoepatcher Posted April 13 Members Report Posted April 13 using right or left twist? glenn Quote
Moderator Wizcrafts Posted April 13 Moderator Report Posted April 13 18 hours ago, MikeRock said: Wiz, Do the curlicues have anything to do with the twist of the thread, left vs. right? Sometimes, if the thread is very coily, knots will form on the top of the leather. The same twistiness can cause the thread to jump out of the business area of the tension disks, or bobbin spring. Weaver thread is known for this problem in the darker colors. Black and dark brown are the worst offenders in this regard. I try to counteract clockwise coily thread by wrapping it counterclockwise around two holes in the top thread guide post on my Cowboy CB4500. It really does help cut down on the twisting at the needle. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
MikeRock Posted April 13 Report Posted April 13 Wiz, Thank you. I had a similar problem and changing twists cured it. God bless Quote
