Members ChesterHasAProblem Posted April 14 Members Report Posted April 14 Good day, I am looking to buy a few basic tooling stamps. What are some brands you would recommend that are better than Amazon and cheaper than Barry King? I was considering getting the Tandy Basic Stamping Set, but it was described as only for children. Your input is appreciated, Thank you. Quote
Contributing Member fredk Posted April 14 Contributing Member Report Posted April 14 Buy Tandy. They're fine. They very good as a starter set. If you can go into a Tandy and inspect the tools. Make sure the shaft is straight. Check the design, make sure there is no flaw on it. Quote
Members JDFred Posted April 14 Members Report Posted April 14 Craft Japan make decent stamps i would put them on par with 70s vintage crafttool stamps. the ones I have I got from proleathercarvers.com Quote
Moderator bruce johnson Posted April 14 Moderator Report Posted April 14 Decide what you are interested in first. People say “I don’t like basket stamping patterns” but you can learn a lot about casing and ideal moisture with a basket stamp and a border. Want to carve? Then get the basic stamp set and play with it, that will help you decide if you like it. It will also give you a basis for which stamps to upgrade and the sizes that fit your projects. As you go along you will find a whole range of stamp makers, some priced more than others. Barry King is still a pretty good bang for the buck. You may decide this is not for you or you got a stamp you just don’t use. The resale is generally good for Barry King and higher end stamps. Quote
CFM chuck123wapati Posted April 15 CFM Report Posted April 15 I'll add some stamps don't need to be top quality to work well while others do need to be very precise to get a good effect. Quote
AEBL Posted April 15 Report Posted April 15 Where are you located at, @ChesterHasAProblem? Someone here might be able to point you to a store for used tools ... Quote
AlZilla Posted April 15 Report Posted April 15 On 4/14/2025 at 4:05 PM, ChesterHasAProblem said: Good day, I am looking to buy a few basic tooling stamps. What are some brands you would recommend that are better than Amazon and cheaper than Barry King? I was considering getting the Tandy Basic Stamping Set, but it was described as only for children. Your input is appreciated, Thank you. Your question reminded me of the following thread where an admittedly talented, accomplished leather crafter turned out a piece using only entry level tools (Tandy). Take a look at the high level of work. We have a few members here who make their own stamps from bolts they've ground to whatever shape they want. So, I wouldn't get too wrapped up about using a starter set. The cost is usually below what you'd spend seperately. Quote
Members ChesterHasAProblem Posted yesterday at 01:13 PM Author Members Report Posted yesterday at 01:13 PM (edited) Thank you all for your input. I decided to go with the Tandy set. Am now working on an online tooling course by Jim Linnell. I will see how it turns out. Edited yesterday at 01:13 PM by ChesterHasAProblem Quote
