Hello everyone, ive been a long time lurker and this is my first time posting excited to be joining the community.
Here's my issue and what I think might possibly work but afraid to try and id like to hear what everyone advises.
I've got a large hide that id like to thin down to be more workable for what I need, buying a splitter isnt an option and manually skiving it with a knife or skiver is leaving me with ridges and is going take a hell of a long time. I was thinking of applying contact cement, letting it stand for a while and then placing a canvas over that and basically ripping some of the flesh side off, kind of like if you think about how someone gets hair waxed off their body.
I got the idea from a mistake I made and trying to detach 2 pieces the way one side almost cleanly ripped a layer's worth of flesh off.
Im wondering if anyone has any advice, tried anything similar with success or has another way to do this that wont make my arm full off from manually skivving
thanks everyone!
Welcome from Southwest Missouri, USA.  I think the method you describe will give you undesirable results.  It would almost be worth buying a new piece at the thickness you need and saving this one for thicker jobs in the future.  I have multiple rolls of leather, all different thicknesses.
In God's Grace,
Pastor Bob
"While we were yet sinners, Christ died for us." - Romans 5:8
www.PastorBobLeather.com
YouTube Channel
I agree with wot he said
  • CFM
i would try a sander before giving up, I've thinned small pieces, straps, and such with a belt sander. I also do my edges with a belt sander.
Personally, I would only thin what I need at the time because it is difficult.
The sander will burn your leather, pretty easily, so you have to be careful!!
Buying a thinner piece if you have the choice is preferable, then you have more leather for more projects lol.
Holy shit you guys are fast. Did not expect a reply this quickly! To PastorBob's point I agree and normally I would but this pesky roll has been lying around for close to what feels like a millennium and id like to do something manageable with it rather than throw it out. it might just end up becoming a stack of new coasters
to chuck123wapati, I dont have one unfortunately but ive tried a sanding down some bits with a drill attachment on a drill to varying success. I always seem to lose control of one thing or the other lol.
Thanks guys!!
scrub plane very very sharp
Belt sanders and sanding disk drill attachments, ouch, I can see where they'd go if I tried them, if I tried a power sander I'd go with a finishing sander or maybe a random orbital sander.
I've heard of wood planes being used before although I would have thought a scrub plane would leave you with an undulating finish, I don't own one so I have no idea if this would actually be significant, personally I'd try a regular plane or a low angle plane, got an ideal piece of leather to try that out, yet another item on my looong ToDo list 😕
Mark
Mark
Expand
Just the corners of the iron are rounded, you are right, a full ellipse on the edge would not be the way to go. I have done this, and it works very well.
  • CFM
Expand
i don't doubt that a bit. Drills with attachments aren't Sanders, lol. A belt/disc sander is standard equipment in my shop. I use it on almost every project I make. they make great tool sharpeners also.😉
  • 2 weeks later...
If you're using a drill press, be careful applying pressure radially to the bearings (i.e. pressure in the plane of the support table). This will likely cause your bearings to wear out if you do that a lot. Drill presses are designed for "up and down" pressure, but not "left and right" or "forwards and backwards" pressure.
Some sharpening systems use a spinning disk are probably fine (basically up and down pressure), but using a drill press as a drum sander is not recommended.
