  • Ambassador
I came up with this pattern and think that I am going to make a belt or new mandolin strap for myself. If any one would lke to carve it I
I'de love to see what you all come up with.
While I have your attention- how about a pattern section for submissions to try. I used to look froward to Tandy's flyers and doddle pages when I was young. we could have our own here and maybe combine it with the other posts regarding a carving contest online.
Pete, I like it alot.The leaves are cool and I want to try them. I wasn't able to get them to print but will try again later. Very nice pattern. Dan
If you haven't got time to do it RIGHT How are you going to find the time to do it OVER ! Dan Hammons http://highcountryleatherart.com/
  • Ambassador
Thanks Dan! If you take the right hand strip first and put the left hand strip under it they go together to make a continuous pattern. I like making long patterns for belts so that I don't have to keep using the same short piece over and over. Plus you can make the pattern a lt longer so that it doesn't repeat so often.
Thanks again- it's my first attempt at patterns since writing to Dave Ganedek and seeking his expertise.
I'de LOVE to see what you could do with this even if it is a practice piece. I plan to make the belt and show it here too.
pete
I'll be gone this weekend but plan on carving it and will also post my carving! Thanks Dan
  • Ambassador
I don't have a scanner so I hope that this helps
pete
  • Ambassador
pete
Edited by pete
  • 2 weeks later...
  • Ambassador
here's what I came up with. It's my first attempt at pattern drawing and I LIKE IT. NO prize winner but......
Now I remember why I hate to make belts. Too *&^$&^ to carve what with all the turning and awkward angles.
pete
Pete,
Sometimes the space defines the design sometimes the design defines the space. In this case I think you have a design defining the space. I would try loosing the border and carve it as an inverted design. I think then you might say I have a prize winner. The style I see emerging from you is one where the design does define the space so this is not "Sheridan" it is Peterdan. Go take a look at Peter Mains site, his style of design and carvng would be the best complement for where I see you going.
David Genadek
pete
  • Ambassador
I like that pattern. I am going to have to give this one a whirl, when I get time (ROTFLMAO).
Shawn Zoladz (The Major)
dba Major Productions
Everything Leather
Saddles and Shoes Excluded
You can lead me. You can follow me. Or you can get the hell out of my way.
-Gen. Geo. S. Patton
  • Ambassador
ok folks- here is the finished piece. I wanted the VOGHT buckle set but didn't want to put out $3500.00 so I skimped a bit and spent $19.95 at Tandy for a plated set. Doesn't look to bad from a distance in the dark. serioously- it's a really nice set and well worth it.
I look forward to you others that wanted to do this pattern.
sincerely
Edited by pete
