Members dikman Posted August 5 Members Report Posted August 5 Basically a manual clicker press, I saw one on youtube and thought that looked useful. Amazon (Aus) had what was an older version with needle bearings on the shaft end for what was a good price ($178) and by signing up to their app (which I won't use again as I prefer using my computer) I got another $20 0ff. $158 delivered was too good to pass up. It arrived today, well packed, and I forgot how heavy 50lbs is!!! This thing is built like a tank! As a bonus it is the later model with big bearings on the shaft ends. So, the base and pressure plate are made from 5/8"/16mm plate steel, the main support bar is 1 1/4"/30mm bar and the upright bolts are 3/4"/17mm rod. The end bearings are 1 3/4"/45mm diameter and the pressure plate 10.2" x 4.7"/260 x 120mm. I'm glad I didn't get a bigger one because of the added weight. It has a travel of 1/2"/12mm and claimed downward pressure of between 1 - 1 1/2 ton, depending on which article you read. A quick trial of the only clicker die I have handy (lent my other ones to a mate) and it went through the leather like butter! Should be good for imprinting things too. Me happy. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members DieselTech Posted August 5 Members Report Posted August 5 Yeah I got 1 of the vevor's about a year ago. It does everything i need it to do. I also had some custom dies made by weaver & i highly recommend them if ever looking for cutter dies. Quote
Members dikman Posted August 5 Author Members Report Posted August 5 Being in Australia getting dies made by Weaver isn't really an option. I'd like to have a go at making dies but so far haven't been able to source rule steel here in Oz. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
kgg Posted August 5 Report Posted August 5 8 hours ago, dikman said: This thing is built like a tank! Nice you should get good use of it. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members dikman Posted August 5 Author Members Report Posted August 5 It will certainly out last me! If used as intended (or possibly even abused!) I can't see any fail points on it, an unusually well made bit of Chinese gear. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members dikman Posted August 8 Author Members Report Posted August 8 Well, I've run into one problem, although it's not the machine's fault - I can't find anywhere local to buy the steel rule that the dies are made from. So far all my searches lead to the US or Alibaba, and they have minimum sale requirements of usually 100 metres! Why do things have to be so hard..... Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
