Members Johnmostyn Posted August 6 Members Report Posted August 6 Hi All, if I use resolene over antique paste, can I use Aussie leather conditioner on the leather after the resolene has dried? thanks Quote
Northmount Posted August 6 Report Posted August 6 4 hours ago, Johnmostyn said: Hi All, if I use resolene over antique paste, can I use Aussie leather conditioner on the leather after the resolene has dried? thanks Moved your post to Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners. You should check this forum out. Lots of good info and experience here. Resolene seals the surface of the leather. So conditioners such as oils and greases don't penetrate the sealant. Quote
Members ThisIsMyFirstRodeo Posted October 24 Members Report Posted October 24 On 8/6/2025 at 8:01 AM, Northmount said: Moved your post to Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners. You should check this forum out. Lots of good info and experience here. Resolene seals the surface of the leather. So conditioners such as oils and greases don't penetrate the sealant. If the flesh side isn’t sealed, can it be oiled/conditioned from there? — AZR Quote
Members SUP Posted October 24 Members Report Posted October 24 Aussie's is mainly petroleum jelly. It could make the flesh side sticky. Quote Learning is a life-long journey.
Members Dwight Posted October 24 Members Report Posted October 24 On 8/6/2025 at 6:54 AM, Johnmostyn said: Hi All, if I use resolene over antique paste, can I use Aussie leather conditioner on the leather after the resolene has dried? thanks What would be the purpose of the conditioner??? Resolene pretty much seals up the leather . . . I've never put on 4 or 5 coats . . . but I'd come close to betting that it would be water proof by then. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members ThisIsMyFirstRodeo Posted October 24 Members Report Posted October 24 1 hour ago, Dwight said: What would be the purpose of the conditioner??? Resolene pretty much seals up the leather . . . I've never put on 4 or 5 coats . . . but I'd come close to betting that it would be water proof by then. May God bless, Dwight My thought was that it would help keep the veg tan a little more pliable. (I have NFO and saddle soap though) Usually I stiffen leather, and use 6-8oz instead of 3-4oz, so this is just the opposite end of the spectrum for me to learn. — AZR Quote
Northmount Posted October 25 Report Posted October 25 On 10/24/2025 at 12:09 PM, ThisIsMyFirstRodeo said: If the flesh side isn’t sealed, can it be oiled/conditioned from there? — AZR It can be, if it is accessible. I wouldn't use anything greasy that could be transferred to other items. The flesh side may not be able to be buffed to remove any excess. Some hides are rough and stringy. I wouldn't make a practice of doing the flesh side, only if I really had to. Quote
wizard of tragacanth Posted October 26 Report Posted October 26 What kind of project is this? I may have missed it in previous posts. Quote Nick
Members ThisIsMyFirstRodeo Posted October 27 Members Report Posted October 27 (edited) On 10/25/2025 at 5:17 PM, wizard of tragacanth said: What kind of project is this? I may have missed it in previous posts. It’s a handbag, 3-4oz econo veg tan, probably closer to the 4oz end. I was hoping to attempt oiling/conditioning to soften it and make it a bit more pliable (I know I would have only limited results, but I was going to try anyway), but because I made the mistake of using a water-based dye, I had to seal the bag with Pro Resist (it’s what I have on my shelf), which leads to the conundrum of how to best treat the leather. — AZR Edited October 27 by ThisIsMyFirstRodeo Extra detail Quote
