Members councilman24 Posted August 13 Members Report Posted August 13 I was trying to get a parachute harness job done last night. I went to rethread the machine and like the forgetful old man I am I forgot to thread through the hidden take up lever. Yes I know, but I haven't had it long, it was 3 am and I'm forgetful. I actually teach new riggers how to sew so yes I no better. So, or course a bunch of thread got bound up around the hook and bobbin. I cut the work loose, opened up the cover, pulled out the loose thread. Hand wheeled around and the needle was hitting part of the hook. I was confused and pulled door assembly off and pulled hook out. Of COURSE, I forgot to tighten the inner race spring lock. By the time I remembered about the lock I had managed to pull the inner race out from behind the hmm, hook driver? What ever that part is called. And now I can't get it back behind to lock it back in place. I did manage to find the one spring that fell out. Any help on how to get the inner race back there without complete disassembly? I got it out but I've tried an hour to get it back. Also it seems like the timing is off a lot, like 180 degrees. Do the two halves of the drive shaft under the clamping rings slip around one inside the other? The timing instructions in English are poorly translated and confusing. Given that I have to retime the bottom anyway maybe releasing the clamp rings and what ever I have to do to get the driver out won't be much more. Any videos on timing hook? Couldn't fine any from Uwe or anyone else. Help? Photos in a few minutes. Terry Quote
Members councilman24 Posted August 13 Author Members Report Posted August 13 I just figured out the trick to get the inner race in. I couldn't get it in with the springs in place. But you can with the springs out. Then you can turn the race to match the half circle cut outs in the surrounding structure with the half cir le cutouts on the race. Insert the spring. A needle helps with line up. Then turn handwheel to allow race to turn and line up another spring. Got all four in, lined up race cutouts for for door assembly bolt, and then pressed in and locked ba k with ser screw. In photo you an see one spring in and hole lined up for another. This is the kind of trick that can save hours. And obviously was intended with half cutaways in stationary out side rim. I was trying to figure out why those cutout were tpmhere. That's what led to figuring out how to do it. Quote
Contributing Member friquant Posted August 13 Contributing Member Report Posted August 13 Nice work! I aspire to own a machine like this someday, so tucking these notes away for future me 😀 Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
Members Goldshot Ron Posted August 13 Members Report Posted August 13 Weaver has a good video on Youtube for timing your 205. Quote
Members councilman24 Posted August 13 Author Members Report Posted August 13 46 minutes ago, Goldshot Ron said: Weaver has a good video on Youtube for timing your 205. Not that I can find. Found one on setting neesle bar height bit not on turning shuttle timing. I figured it out and it's sewing but don't know what I don't know. Quote
Members councilman24 Posted August 13 Author Members Report Posted August 13 2 hours ago, friquant said: Nice work! I aspire to own a machine like this someday, so tucking these notes away for future me 😀 This is the only machine that has this spring loaded shuttle race. Unless Adler's new one, 969 I think, does. Quote
Members Goldshot Ron Posted August 15 Members Report Posted August 15 Sorry, I must have imagined it. I could not find the timing video either. But, Uwe Grosse has some on Youtube that are informative, and there is a Weaver video that offers good information on a 205. One problem I had when I first got my 205 was that I had to order two extra shims to fit behind the collar on the bobbin to accommodate 346 size thread. There was certainly a learning curve between the Adler and a clone 205. Good luck. Quote
Members Cumberland Highpower Posted August 16 Members Report Posted August 16 (edited) hmm. Edited August 16 by Cumberland Highpower Quote
Members Constabulary Posted August 16 Members Report Posted August 16 Looks like the shuttle race is not installed correctly, Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
