Members TomE Posted September 15, 2025 Members Report Posted September 15, 2025 I am starting to sew halters made from 2-3 layers of Biothane Beta 520 super heavy (3.5-4 mm thick) on a Cobra Class 4. I am having problems with skipped stitches, mainly when backstitching 2-3 layers near hardware. I am using a holster plate that allows me to stitch closer to a center bar buckle. I did make small adjustments to the hook timing, following @Uwe's video on Youtube. Thanks, Uwe! The machine sews leather fine. My current setup for Biothane is the Hennigan Precision holster plate with feed dog, the Hennigan narrow presser foot set, #207 thread top/ #138 thread bottom, size 24 794 7x3 round point needle, and 5-6 stitches per inch. This setup buries the knots in a single layer of Beta 520 super heavy. I have also tried #277/#207 thread with needle sizes 27, 26, and 25. I've done a limited test of cutting point needles but I like the thread tension with round point needles. I have used the stock holster plate and harness feet that come with the Class 4 for the larger thread and needle sizes. Still get occasional skipped stitches. The information for needle choices that I've read in this forum and seen on Youtube is contradictory. Most suggestions are to use round point needles that are 1-2 sizes larger than what would be used for sewing leather. I haven't yet tried thread lubricant, and I haven't played with presser foot tension. I don't notice flagging while sewing. I mainly sew bridle leather on this machine and would prefer not coating the thread path with lubricant, but I am open to suggestions. I appreciate your advice on machine setup and best practices for sewing Biothane. Quote
Contributing Member friquant Posted September 15, 2025 Contributing Member Report Posted September 15, 2025 2 hours ago, TomE said: I am having problems with skipped stitches, mainly when backstitching 2-3 layers near hardware. Is there any visibility into that machine, for instance removing a cover so you can see the skipped stitch with a flashlight as it's happening? Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
Members TomE Posted September 15, 2025 Author Members Report Posted September 15, 2025 35 minutes ago, friquant said: Is there any visibility into that machine, for instance removing a cover so you can see the skipped stitch with a flashlight as it's happening? I don't have a clear plate to view the hook, and it seems to only happen with the holster plate. I'm going to reconfirm that leather sews without skipping stitches using the holster plate. I am guessing that the skipping is caused by friction on the upward stroke through biothane, causing flagging even though I'm not feeling it. With a size 25 needle and #207/#138 thread the knots were on top, even after considerable decrease in top tension, so I installed a size 24 needle and that buried the knots. I guess I could switch back to the larger needle and try increasing the bobbin tension. If I can't find the right needle and thread combination then I guess lubricating the thread is the next step. Quote
Contributing Member friquant Posted September 15, 2025 Contributing Member Report Posted September 15, 2025 26 minutes ago, TomE said: I installed a size 24 needle and that buried the knots What size needle did you use for your initial timing? Does your machine require the shuttle to be shimmed when changing needle size in order to maintain the same hook-to-needle distance? Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
Moderator Wizcrafts Posted September 15, 2025 Moderator Report Posted September 15, 2025 I used to sew Biothane and heavy webbing in a previous location. I found that I had to move up one needle size, and use a diamond or round point needle. Additionally, I had to double the foot pressure to keep it from lifting with the ascending needle. Running the top thread thru liquid silicon will help the knots move up with less friction. It might help if you adjust your check spring to give more slack top thread as it goes around the hook. Try it on a test strip. Thread color also plays a part in all heavy sewing jobs. Black thread is often double-dipped to get total color penetration. This process stiffens the thread more than lighter colors. You can usually feel the difference when you handle the thread to feed it through the guides on thread stand. Straw color is usually much softer than black. That translates into tighter knots being formed. Tighter knots are easier to pull up in dense materials, like Biothane and thick webbing. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members TomE Posted September 15, 2025 Author Members Report Posted September 15, 2025 42 minutes ago, friquant said: What size needle did you use for your initial timing? Does your machine require the shuttle to be shimmed when changing needle size in order to maintain the same hook-to-needle distance? I had a size 26 needle installed when checking the timing, and I haven't previously noticed any problems with switching needle sizes. To my knowledge, there is no shimming of the shuttle on this 441 clone. I set the hook timing 3 years ago following the same procedure and it's been working fine for leather. I rechecked it yesterday and made some minor changes. Sews fine with leather and one layer of Biothane. The missed stitches occur erratically so I am thinking it's friction and/or how I am feeding material through the machine. 21 minutes ago, Wizcrafts said: I used to sew Biothane and heavy webbing in a previous location. I found that I had to move up one needle size, and use a diamond or round point needle. Additionally, I had to double the foot pressure to keep it from lifting with the ascending needle. Running the top thread thru liquid silicon will help the knots move up with less friction. It might help if you adjust your check spring to give more slack top thread as it goes around the hook. Try it on a test strip. Thread color also plays a part in all heavy sewing jobs. Black thread is often double-dipped to get total color penetration. This process stiffens the thread more than lighter colors. You can usually feel the difference when you handle the thread to feed it through the guides on thread stand. Straw color is usually much softer than black. That translates into tighter knots being formed. Tighter knots are easier to pull up in dense materials, like Biothane and thick webbing. Thank you, Wiz. Lots of good information. I am using black thread from LMC and it is considerably stiffer than other colors. I will test out white thread and fiddle with the foot pressure and check spring tension. Guess I will order a lube pot and lube to find out what that's all about. We mostly use Biothane halters in our barns. They used to affordably priced with stainless hardware, but the prices have risen considerably so I decided to make some for us and friends. Not interested in large scale production of this item and competing on price with bigger vendors. I definitely like sewing leather better than Biothane but this is a good learning experience for me. Quote
Members DieselTech Posted September 16, 2025 Members Report Posted September 16, 2025 As somebody mentioned already, try tightening your foot pressure tighter. Want Lil tiny bit i have sewn woven strap material, it seems the foot slips some on the material & misses a stitch. You could be pushing or feeding the project thru instead of letting the machine doing it.. That could have been my problem as well. I think by increasing foot pressure it minimizes the problem. Quote
Contributing Member Tim Schroeder Posted September 16, 2025 Contributing Member Report Posted September 16, 2025 17 hours ago, TomE said: To my knowledge, there is no shimming of the shuttle on this 441 clone No but you can adjust the needle bar distance/needle from the hook. When I was working on my 441 I thought you would need to adjust this when going from a #19 needle to a #27. I think maybe you commented on this issue. Cowboy Bob sent the directions on how to do it. Quote
Members TomE Posted September 16, 2025 Author Members Report Posted September 16, 2025 5 hours ago, DieselTech said: As somebody mentioned already, try tightening your foot pressure tighter. Want Lil tiny bit i have sewn woven strap material, it seems the foot slips some on the material & misses a stitch. You could be pushing or feeding the project thru instead of letting the machine doing it.. That could have been my problem as well. I think by increasing foot pressure it minimizes the problem. I have increased the foot pressure and switched to white thread. This seems to have fixed the problem with skipping stitches. I ordered thread lube and a pot, and hope to switch back to stiffer black thread with lubrication. I am figuring out how to feed Biothane while sewing close to hardware. For leather halters I typically add a wedge/welt to ease the transition in thickness and sew tight to the hardware. Biothane is stiff and springy when folded around hardware so it's a new experience negotiating the ends of the straps. The feet want to slip back down the slope as the material compresses while sewing on a slope. Beta biothane is a matt finish and relatively grippy compared to bridle leather, but the flattening of the loops as they are sewn is a new dynamic for me. 54 minutes ago, Tim Schroeder said: No but you can adjust the needle bar distance/needle from the hook. When I was working on my 441 I thought you would need to adjust this when going from a #19 needle to a #27. I think maybe you commented on this issue. Cowboy Bob sent the directions on how to do it. Thanks for the reminder, Tim. I will check the needle/hook distance. I am settling on a size 24/25 needle, which is what I've been using for leather (cutting point, not round point) on this machine without any issues. Quote
Moderator Wizcrafts Posted September 16, 2025 Moderator Report Posted September 16, 2025 23 hours ago, Wizcrafts said: I used to sew Biothane and heavy webbing Coincidentally, I had a customer come to my shop yesterday with a dozen webbing straps that I had to sew together in pairs, at the loose ends, with a 3" overlap. I chose #138 yellow bonded polyester thread and used a #23 round point needle. I had to retime/advance the hook to avoid skipped stitches in reverse, and adjust the check spring throw, in addition to increasing the bobbin and decreasing the top tension. All of the tension changes will have to be undone when I have to sew a holster or sheath. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
